Losi 8ight building and setup
#1891
Originally Posted by slow
I ran out of shock bladders so I've been running my shocks with just an oring in the cap, filling the shock and cap with oil, and bleeding properly. I really haven't noticed a difference.
Should there be a difference? Has anyone else done this?
#1892
Originally Posted by SupermaxxRich
weird, that should pressurize oil past your bottom o-rings...
#1893
i know its probably in here but can somebody tell me the best fitting and best working starter box is? im not worried about the price i just want something that isnt going to give me a problem. thanks.
#1894
I'm using the Mugen starter box with no modifications. Works great + it's small & light. Works on 2 electric rc-car stick packs so the voltage (therefor RPM) is a little higher than the single 12V batery started boxes.
#1895
most people use the mugen (mugb0230)......it's a direct fit. good luck finding one however. they are out of stock just about everywhere.
#1896
the mugen. thanks guys. well all out of stock well i got til spring cuz im in MA and its snow and cant do too much riding,electric for now. just getting prepared. maybe there is one in -for sale forum- thanks
#1897
I will add that if you get a new one, it's a kit, you have to build it.
#1898
Hey guys
Hey guys I just insalled my kingheadz radio tray stiffiner and I was wondering if this is a ok place to mount my PT. Sorry for the bad pictures I took it with my cell phone.
Now I was wondering if this is a ok place to mount it, What I mean is it will not interfier with anything else. I also made sure no wires were by the spur gear so the spur gear would not shread right threw them. Because you have to cut 2.5mm off the spur gear cover for the radio tray stiffiner to fit. So tell me what you think.
#1900
Thanks micros4guy And also I was wondering how does it work out there for you. Also you are running the radio tray stiffiner right. I was wondering if you had to cut 2.5mm off the spur gear cover also and did you have to tuck your throttle servo wiring in so your spur gear would not shread it. Thanks again.
#1901
what is the purpose of the radio tray? does it make the car go fastr? and isnt cutting the spur gear like a no-no?
#1902
hey
Hey Tre I think you read it wrong. I put a radio tray stiffiner on and the radio tray is to hold all of your electronics. And I did not cut the spur gear I cut the cover that covers the spur gear the cover is plastic so I had to trim it down for the radio tray stiffiner to fit. Do you get it now.
#1903
Hey, guy's and gal's. Anybody doing the RC pro series in Texas this year?
#1904
very well explained. got it now! you wonder why the eight isnt already got something like that set up in it?
#1905
Dunno, i guess were the ultimate tester's, I mean if i cant break this car no-one can.. Oh wait i did break ... But it wasnt my fault....It's never my fault....
