Roche Rapide F1-2016 >
Like Tree8Likes
Old 03-18-2017, 11:49 PM
  #226
Kevin CBR's Avatar
Trader Rating: 11 (100%+)
Originally Posted by bkspeedo
Kevin or anyone else. Have you tried raising the rear pod roll center? This is done by placing shims between the chassis and pivot ball assembly on the 2 crews that hold it into place and remove the appropriate shims from the front link mount point. What I'm currently doing and everyone at 5280 that owns a Roche F1 now has done this and seen an improvement. Remove the 1 mm shims from the front link mount point and place them under the rear pivot ball assembly. Effectively raising the rear pod 1mm. Makes the car rotate better from the rear. When the grip is high I also only dope the center of the rear tire. About the width of the SXT dauber which is about 60-70% of the tire.
This car has been very dominate at 5280 since Kyle and I started running it here.
Thanks for the tip and will give it a try. I will be sure to see you and Kyle when I come up for the MHIC race in April for any set-up help. Need to keep Mario and Dumper honest with their CRC's.
Panda 🐼
Kevin CBR is offline
Old 03-19-2017, 05:26 PM
  #227
Trader Rating: 42 (100%+)
Interesting.
Will test this next time out.
Nexus is offline
Old 04-03-2017, 03:09 AM
  #228
So the pod is 1mm higher than the chassis?
nicoo2k4 is offline
Old 04-03-2017, 06:52 AM
  #229
hanulec's Avatar
Trader Rating: 28 (100%+)
Raising the rear roll center. All 5 pivot balls raised
hanulec is offline
Old 04-03-2017, 07:44 AM
  #230
Default picture of the tips...
can we see some pictures of these new tips ? Thank you in advance...
Mafodda is offline
Old 04-03-2017, 11:06 AM
  #231
bkspeedo's Avatar
Yes, as Mike mentioned all Pivot balls raised. You'll need to adjust the rear axle height so the rear pod is flat.
By adding 1 mm shims under the 2 screws that hold the pivot ball assembly in place but not the pivot ball screw itself will raise everything on the rear pod.
I ran my car this weekend on low grip carpet and had to remove this change as it made the rear of the car slide around or rotate to much. Proving that in very high grip conditions, like those on Black CRC carpet, this change is really good.
bkspeedo is offline
Old 04-03-2017, 11:09 AM
  #232
bkspeedo's Avatar
Mafodda,
Sorry as mentioned in the previous post i changed my car back to normal this weekend. Want to do a little testing in it's current state before raising again. Here's a drawing marked up from the manual.
Nexus likes this.
bkspeedo is offline
Old 04-14-2017, 06:34 AM
  #233
Trader Rating: 22 (100%+)
Looking for a set up for CRC Black carpet with transverse battery and Fenex gear diff.
Any help would be greatly appreciated
Grumpybrat is offline
Old 04-14-2017, 08:46 AM
  #234
bkspeedo's Avatar
Russ i'm working on getting you a setup from someone that did well at Snowbirds who ran transverse battery.
I'll be at the track today and Sunday. Let me drive your car again. If all else fails glue the sidewalls.
bkspeedo is offline
Old 04-14-2017, 01:51 PM
  #235
hanulec's Avatar
Russ - https://drive.google.com/a/rochercus...w?usp=drivesdk
hanulec is offline
Old 04-14-2017, 02:44 PM
  #236
Thank you
Old 04-28-2017, 10:07 AM
  #237
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
Other than the Mon-Tech body, what body is common for CRC Black Carpet?
Which setup would you recommend as a starting point at 360v2?
dr_hfuhuhurr is offline
Old 04-28-2017, 10:20 AM
  #238
hanulec's Avatar
Any body should fit
Kyle Klingforth stock wars setup is dialed
dr_hfuhuhurr likes this.
hanulec is offline
Old 05-01-2017, 01:41 PM
  #239
Originally Posted by old_dude
Getting the drag brake and push brake right really helps F1 cars. Battery position is also super critical. Another big help is the ABS setting in the radio.
Can anyone explain what specifically they are doing with Drag Brake/Push Brake and ABS on the F1 cars?
Also, eta on aluminum chassis coming back in stock?
Old 05-02-2017, 10:39 AM
  #240
just got a roche f1 kit.....
any recommendations on whether to use 48 or 64 pitch gears..
planning on racing asphalt outdoors.....
socalracer27 is offline
