Viper R/C Solutions - A New Line of Innovative Power systems!
#647
Are you talking 100º C or F? If your saying Celsius and reading outside the can, that is way too much for almost any motor on the market, for sure it means almost 130ºC inside the motor and way over melting point.
#649
Yeah, that looks really low temp. Check the programming and comeback for feedback.
#652
you wil notice a big improvement in power between the a19 and the a23 version
#653
As i said before the ESC reads inside the motor and that could lead to some huge diferences such as 80ºF around 30ºC, if you read that on the can and it could be just seconds after the switch off, it's easy to the ESC have read it 220ºF inside the motor.
#654
It's a huge diference specially in boosted and pay attention that the new firmware is not yet ROAR approved for non timing.
#656
Send me your mail trough pm.
#658
Nope, will send you by mail ASAP because i forgot you didn't have.
Sorry.
Sorry.
#659
I didn't see an answer to this specific question... although we have discussed it before.
The VTX10 speedo is not a 1S lipo compatible speed control. However, most non-1S compatible ESCs can be used with a rec pack or booster, by disabling the low voltage cutoff... or by leaving the ESC turned off(in the case where the LV cutoff cannot be turned off).
Obviously the VTX10 is not 1S compatible. And, from my readings in the instruction manual, it appears that the LV cutoff only goes down to ~4.2 volts? And it doesn't appear that it can be disabled altogether.
So.... the question is.... with a rec pack or booster, can the VTX10 be run with a 1S lipo with the ESC turned off(like people were doing with the Tekin RS before hte updated firmware came out)?
#660
the viper speed controls cannot be ran with rx packs. it doesn't like them becuase of the micro proccessor in the on/off switch.
but running a booster, the esc has to be able to go down to 3.2v or below on the esc's cut-off and you have to remove the low voltage cutoff on the booster like the novak one in order for it to work as the speedo turns itself on once the switch on the booster is turned on because of the micro proccessor.
I have been running one of the origional prototypes of the vtrax1 esc from the first batch that had an internal booster issue and have put one of the novak boosters on it and have ran it for about a year now and this is what i have come up with in that time. Currently i am still using that one and i am also running the newest version of prototypes and so far it has been flawless . so it shouldnt be too much longer before the vtx1 is in production . but dont quote me on that!
