Around The Table With Paul Lemieux(RC-America/Thunderpower)
#961
Suspension tuning
Hey Paul,
I have been following this thread for sometime now, very interesting stuff here.
I believe I am an OKAY driver but probably the world's worst mechanic needless to say I have a few questions.
1. When you get to a new track (layout) what is first ting you work on, gearing suspension setup etc?
2. dampening and piston choice. When and why would you say go to a lower viscosity oil as opposed to using a piston that has more holes?
3. when would you go to a harder spring as opposed to stiffening the swaybar, don't both take way roll?
4. When tuning rubber tires what do you look for, is tire wear something to look for, do the tires ell a story? The reason I asked is that in spec classes you get 2 sets of tires how do you take care of these?
I know it's a lot but this has been bugging me
#964
LiFe A123 batterie
Hi Paul and everybody els.
I was running at my home indoor track (PK modelracing) I met a racer from Belgium and he was running LiFe batteries and they did a fine job.
He was running 1:12 scale with this batteries and charged them with over 10amp this took him 10 minutes and he is running again for 7 minutes of so.
He runs this batteries a few months and he says you can discharge them completely and charge them without damaging the battery and i have watch this closely. He sayd it is a cel invented in the US by a factory A123 and also he is telling me that the Walt powertools used them as power supply.
Has anyone expirience with this batterie, i planned to use them in my X-ray.
The capacity of these cels is 2300mAh by nom.3.3V I planned to use them instead of my 5celNiMh batterie two sets parallel and those in serie wil give
6.6V at 4600mAh.
Sorry for this long story, but i looking forward for somebody with expirience for this remarkable batteries.
Thanks Ed
6.6V at 4600mAh.
Thanks Ed
#965
6.6V at 4600mAh.
Thanks Ed
6.6V at 4600mAh.
Thanks Ed
A 2s2p 4600mha can be safely charged at 20A, if you can find a way to get all that current
The bad news is it is bigger than nimh or most lipo packs. 26mm height, and wider than nimh. Im prety sure it wont fit under the xray top deck without some modding.
It will be easier to balance the chassis though (slightly heavier than lipos, but less than 5 cell).
#966
All what you said is correct. A123 make a great substitute for 5 cell, voltage is probably a bit less than a fresh matched pack so you will have to gear up maybe a tooth or so. Top speed will be identical or a bit moore, smooth botom end. Runtime is 20-30% more.
You are right the dimensions diam=30 length=54 if i am right are big the weight is that of a LiPo, but the good news for now is that Graupner has different dimensions.
I have to study their side.
Chargers for Life batteries are available to 10Amp this mean charge time is only 30 minutes.
The mounting in Xray is besides the topdeck and that is Ok for the car balance.
#967
Worlds
Yo Pauly....Kick some ass next week (or whenever) you are leaving. The cell number I have for you is some dude that has no idea who you are, so I am assuming its the wrong number! Good luck man! Tell Deiter MF says whats up.
#970
Hi guys, im sorry that i have not been on here much for the last few days. I have just been super busy with prepairing for the worlds and trying to spend time with my family before i leave. ill be back on here in a couple of weeks after the event. thanks for your support and understanding, Paul
#975
Best of luck Paul from all of us at RCP, thanks for all the help you have given us and everyone.
Jim
Jim
