Closed Thread
Old 10-31-2008, 08:24 AM   #961
trickd122's Avatar
Default Suspension tuning
Hey Paul,
I have been following this thread for sometime now, very interesting stuff here.
I believe I am an OKAY driver but probably the world's worst mechanic needless to say I have a few questions.
1. When you get to a new track (layout) what is first ting you work on, gearing suspension setup etc?
2. dampening and piston choice. When and why would you say go to a lower viscosity oil as opposed to using a piston that has more holes?
3. when would you go to a harder spring as opposed to stiffening the swaybar, don't both take way roll?
4. When tuning rubber tires what do you look for, is tire wear something to look for, do the tires ell a story? The reason I asked is that in spec classes you get 2 sets of tires how do you take care of these?
I know it's a lot but this has been bugging me
trickd122 is offline
Old 10-31-2008, 10:07 AM   #962
beavis353's Avatar
Originally Posted by Paul L View Post
Barry does look a little like the fonz.
One critical difference. The Fonz actually had GAME.
beavis353 is offline
Old 10-31-2008, 10:27 AM   #963
mtbboy's Avatar
Heeey, Cmon guys just beacause Barry is ugly doesn,t mean you can make fun of him.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline
Old 10-31-2008, 03:51 PM   #964
Default LiFe A123 batterie
Hi Paul and everybody els.
I was running at my home indoor track (PK modelracing) I met a racer from Belgium and he was running LiFe batteries and they did a fine job.
He was running 1:12 scale with this batteries and charged them with over 10amp this took him 10 minutes and he is running again for 7 minutes of so.
He runs this batteries a few months and he says you can discharge them completely and charge them without damaging the battery and i have watch this closely. He sayd it is a cel invented in the US by a factory A123 and also he is telling me that the Walt powertools used them as power supply.
Has anyone expirience with this batterie, i planned to use them in my X-ray.
The capacity of these cels is 2300mAh by nom.3.3V I planned to use them instead of my 5celNiMh batterie two sets parallel and those in serie wil give
6.6V at 4600mAh.
Sorry for this long story, but i looking forward for somebody with expirience for this remarkable batteries.
Thanks Ed
eded1 is offline
Old 10-31-2008, 06:48 PM   #965
6.6V at 4600mAh.
Thanks Ed
All what you said is correct. A123 make a great substitute for 5 cell, voltage is probably a bit less than a fresh matched pack so you will have to gear up maybe a tooth or so. Top speed will be identical or a bit moore, smooth botom end. Runtime is 20-30% more.
A 2s2p 4600mha can be safely charged at 20A, if you can find a way to get all that current
The bad news is it is bigger than nimh or most lipo packs. 26mm height, and wider than nimh. Im prety sure it wont fit under the xray top deck without some modding.
It will be easier to balance the chassis though (slightly heavier than lipos, but less than 5 cell).
Itchy is offline
Old 11-01-2008, 01:50 PM   #966
Thanks Itchy for your reply.
You are right the dimensions diam=30 length=54 if i am right are big the weight is that of a LiPo, but the good news for now is that Graupner has different dimensions.
I have to study their side.
Chargers for Life batteries are available to 10Amp this mean charge time is only 30 minutes.
The mounting in Xray is besides the topdeck and that is Ok for the car balance.
eded1 is offline
Old 11-03-2008, 11:10 PM   #967
Send a message via AIM to Matt Francis
Default Worlds
Yo Pauly....Kick some ass next week (or whenever) you are leaving. The cell number I have for you is some dude that has no idea who you are, so I am assuming its the wrong number! Good luck man! Tell Deiter MF says whats up.
www.matt-francis.com
Matt Francis is offline
Old 11-04-2008, 04:52 AM   #968
Kropy's Avatar
Send a message via AIM to Kropy
He must have mistakenly gave you one of his "special friends" phone number
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline
Old 11-04-2008, 08:49 PM   #969
Little_Mike's Avatar
Tell Mr. Moore that Mike says hi
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline
Old 11-05-2008, 08:58 PM   #970
Gravity RC
Hi guys, im sorry that i have not been on here much for the last few days. I have just been super busy with prepairing for the worlds and trying to spend time with my family before i leave. ill be back on here in a couple of weeks after the event. thanks for your support and understanding, Paul
Paul L is offline
Old 11-05-2008, 09:04 PM   #971
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Good luck Paul. See ya in Cleveland.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline
Old 11-05-2008, 09:07 PM   #972
Trader Rating: 23 (100%+)
hey paul, at t-side my tires (jaco blues) after 1 run have a ton of junk on them. i dont want to rub the heck out of them and lose all grip whatsoever. what do you recomend doing for your rubber tires on the track? what do you do for cleaning yours?
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline
Old 11-05-2008, 09:49 PM   #973
spray some motor spray on a thick paper towel and wipe the tire. Works like a charm
Old 11-05-2008, 09:56 PM   #974
thats what i did but maybe i should start doing that again. i used a towel but that is what im worried about is getting the scum off the tire, excess rubber and stuff. my friends said maybe im rubbing too hard, idk.
Mike Adamec
Trackside Hobbies
not home is offline
Old 11-05-2008, 11:04 PM   #975
Jim@RCP's Avatar
Best of luck Paul from all of us at RCP, thanks for all the help you have given us and everyone.
Jim
RCScoringPro.com
LiveRC.com
www.RCPerformance.com
www.MARCCA.com
REEDSBURG RACERS
Jim@RCP is offline
Closed Thread
Custom painted Paul LeMieux DNA 1 Sean R R/C Items: For Sale/Trade 4 02-12-2008 07:24 PM
pit table cyclone Electric On-Road 1 10-29-2006 07:01 PM
Paul Lemieux exint2 Electric On-Road 9 10-17-2006 07:19 PM
Mike Blackstock and Paul Lemieux sign with Xray ctmazzo Electric On-Road 79 01-02-2006 03:01 PM
Pit Table help Joneser Electric On-Road 11 09-01-2003 09:44 AM
