Serpent Cobra GT
#1201
Hey guys I need some help with my cobra gt rtr . I tried install new motor mounts (#600588) the mounts dont line up with my chassis? Also tried a new motor rear cover (#13025) .has no support for crank shaft? Are these the wrong parts?or do I need more? Any help would be great!!! Would like to be able to use bump box.
This is one of my local racers and I would like to find some answers for him.
Z
#1202
I used the stock mounts and changed the flywheel on my non-pull engine so it would work with a box.
#1203
If you mean that when removing the pullstart mechanism the crank pin extensión where the mechanism engaged now stays free, that is normal, all non pullstart engines operate like that, the crank supports itself on the front and rear bearings.
About new motor mounts I don´t have an answer because i use the ones that came with the kit.
AFM
#1206
Someone should machine down the stock RTR mounts so they are lower. That would make it accessible to a bump box without going dremel mode on the chassis. Just an idea but this is what I would try first. Knock a little metal off both sides of the motor mounts (top and bottom) and go from there.
#1208
Glad to know about that and its interior is superb and design vise its look like a Bugatti Veyron , so its demand gets higher in the market ad its speed i superb and every one want to buy it.Thanks for your sharing, i like it so much.
#1209
My SERPENT GT
#1210
Anyone know where you can get the new rtr rear body mount?
#1211
Not sure if this is what you're referring to, but hope it helps.
#1212
That's an option thanks
#1213
Glad to know about the Serpent Cobra,its design is awesome and i think speed is also good than other models.I would like to test it soon because this time i am busy in repairing of another model.
#1214
For those of you that had emailed me/texted me/PM'ed me about my setup at the Byron's race. It is now posted on serpent.com.
