Mugen MTX-4
Old 05-03-2007, 05:42 PM
  #8266
asw7576's Avatar
I think 8.5 kg with metal gears and 0.13sec / 60 degree transient speed is the minimum limit for nitro cars.
I'm using :
SANWA ERG VX, 13kg @ 0.10sec ( MTX4 )
KO PROPO PDS 2366, 13kg @ 0.13sec ( MRX4R, MTX3, G4S )
FUTABA S9451, 8.5kg @ 0.10sec ( MSX, BD, M03, TT01 )
HITEC HS-5995TG, 24kg @ 0.16sec ( Hyper8 )
asw7576 is offline
Old 05-03-2007, 06:31 PM
  #8267
Trader Rating: 28 (100%+)
Originally Posted by RC=Realy_Costly
hey guys, i recently bought a jr ds8455 servo for my mtx4's steering and there was a little contimplation at the shop as to wether it would be good enough in terms of strength. it has 6.5kg/cm of torque, is this enough
how much torque is neccesary when running a high end car??????
cheers
The DS 8455 is 7.3kg/cm at 6 volts. I am going to assume you are using a 6 volt receiver pack. In my opinion, that is enough torque for your car. If you are using a 4.8v pack it is 6.5kg/cm. I still think that is enough torque, but it would be marginal.
Scott Fisher is offline
Old 05-04-2007, 12:05 AM
  #8268
RC=Realy_Costly's Avatar
thanks for the imput, ive decided to stick with it
RC=Realy_Costly is offline
Old 05-04-2007, 08:38 AM
  #8269
Artificial-I's Avatar
Trader Rating: 17 (100%+)
LOL those 3racing unviersals are junk. First run I start the car on the starterbox. Then rev up the motor. Those universals arent even true out of the box. They looked like my r40 shafts after a good couple of wacks (r40 has notorious bent dogbone / shafts). Anyhow yeah , dont waste your money on these things. They are junk.
Ill be sure to note this in some sort of builders guide soon for the mtx-4. Im going to get one going soon.
Artificial-I is offline
Old 05-04-2007, 08:47 AM
  #8270
ProE's Avatar
I heard 3racing universals are bad but it seems there pretty good , look a tad bit beefier and the pin seems thicker so theres less play in the diff cup. I like , I hope they fair well.
I've tried them, and they only lasted 2 race meetings and one practise sessions. The on guy at the trap have a tool that allowed me to replace the pins with mugen pins. The mugen pins last way longer.
Sorry to say it. BUT I TOLD YOU SO.
ProE is offline
Old 05-04-2007, 08:50 AM
  #8271
Yeah I had already bought the items, before searching. After searching I saw multiple people saying they were junk. But more along the lines of worn pins. This one the shafts are wobbling like I intentionally bent them. Ive got to get them out of there soon before they wear out the diff cups and other things.
Itll at least allow me to get by this months race.
Old 05-04-2007, 08:51 AM
  #8272
madbeats's Avatar
Default i told you that 3 shit is crap
Some of you guy's talk alot Junk and act like you know what you talk about but never take advise .. i told you that 3 shit is crap but you want waste you money 3 racing will luv you ..
madbeats is offline
Old 05-04-2007, 09:00 AM
  #8273
I like a lot of their products. I bought with no input from you guys so.....I was in a pinch and had to get these so I chose that option.
I still like my 3racing engine mount, chassis, cf bumper mount and brake disc. All functioning well. As well had a lot of successful pieces on my r40.
Old 05-04-2007, 09:10 AM
  #8274
madbeats's Avatar
fair play to you mate... i did mean to be so mean spirited
madbeats is offline
Old 05-04-2007, 09:20 AM
  #8275
Nitro$junkie's Avatar
Artificial-I i was just like you and brought the 3 racing unis before i read from every one they were junk took about a mounth and the front unis shit them self's and fell apart so i went and brought the skyline racing one's they a big beefy fuckers and they are still in there today with no prob's now having said that about them ive still got the 3 racing unis in the rear with no prob yet (touch wood) iv got a spare pair for when they shit them self's but untill they do ill keep runing them almost a year now (only club racers no big evants) so yeah one mounth on the fronts almost a year on the rear
now i Remember a while back some one posted they did some mods to there fuel tank cant remeber who i think it was RC FOOLS not sure but any ways i think ill try it my self cant remember what he did but i think he just put some spacers under the CF top plate to drop the tank down a bit well ive done just that i put 2mm plastic washer's under the top deck
the hole tank sits 2mm lower to the chassis now ill tell ya all how i find it after some testing tommorow seem's a very simple mod if ya ask me
Nitro$junkie is offline
Old 05-04-2007, 10:17 AM
  #8276
Seisick's Avatar
for unis, i´d stick with mugen! they´ll outlast any brand period, and you can purchase replacements for the worn parts, pins or shafts! even if the hole where the pin sits, can be replaced since they already come with additional holes, almost two years on mine since the mtx3 and they´re still on good shape! use no other! don´t know about skyline though! but for me, mugen makes the best metal, no shittiy spring steel that altough light is no match to mugens!
about the fuel tank, just an additional s3 orings or a small piece of fuel tubing and you´ll get the tank lowered.
Seisick is offline
Old 05-04-2007, 12:02 PM
  #8277
asw7576's Avatar
I bought 8 sets of 3racing universals......... I finished them in 6 months. The problem is the silver pin, it's too thin ( 1mm thick vs. mugen's 2mm thick ). Thankfully I went to Ace Hardware to buy 1mm blank drill. I cut the drill into 5 pieces and they become pins replacement.
Right now, I'm using Mugen universals............ so far so good ( going two years in my mtx3 ).
Remaining products from 3racing I think it's okay, especially the allumnium parts. BTW, I'm not sure if 3racing really use 7075 alluminium for chassis / parts.
asw7576 is offline
Old 05-04-2007, 12:25 PM
  #8278
Diesel Racer's Avatar
Default Brake Disk
I'm having problems with the standard brake disk rubbing the carb on my CRF, I've turned the carb slightly to clear but wonder if any of the after market disks are a smaller diameter?
Any feedback would be appreciated.
Mark
Diesel Racer is offline
Old 05-04-2007, 12:50 PM
  #8279
asw7576's Avatar
Mark
1. Try Kfactory brake disc for G4S. It' slightly smaller diameter.
2. Use bigger pinions ( or both : pinions + spur gears )
3. Go to a machinist and ask him for metal cutting ( very difficult, time consuming, and he might ruin your brake disc ).
asw7576 is offline
Old 05-04-2007, 01:23 PM
  #8280
Thanks for the info asw7576, I'll give the G4S disk a try.
Mark
