What RX Lipo fits a HotBodies D8T? >
Old 02-02-2010, 02:56 AM
Location: Proper beer garden over looking the beach :-)
Default What RX Lipo fits a HotBodies D8T?
I've been looking all over, & can't find one that fits. So far i've tried the following;
ProTek RC 2300mah = too big
Reedy 2100mah = only slightly too big
Suggestions will be most welcome, thanks!
Brodie-72 is offline
Old 02-02-2010, 03:06 AM
thrash metal's Avatar
Trader Rating: 13 (100%+)
Default lipo receiver battery to fit the d8t
you can also add the pro match 2s 2300 mah to your list of batteries that will not fit the d8t. i ordered 2 of these after a rep from pro match assured me they would fit and alas they werent even close to fitting
the only one that will fit that i have found so far is the robotronic 2s 1500 lipo. its nice and compact and fits the d8t box perfectly. they are about 40 bucks a piece.
great batteries with really good runtime.
thrash metal is offline
Old 02-02-2010, 06:21 AM
wallot's Avatar
Robitronic and Nosram 1500mah fit. they are same packs.
wallot is offline
Old 02-02-2010, 06:53 AM
kgombe's Avatar
i got the reedy 2100 to fit.... if you take the little plastic piece that you have to screw down on the battery box... then put the battery in first you should be good...
kgombe is offline
Old 02-02-2010, 06:56 AM
fatdaddy's Avatar
any ideas where you can find one. ive been looking all over, and i cant find any
fatdaddy is offline
Old 02-02-2010, 08:29 AM
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Exactly, same thing with the Protek 2100-2300.... ran them all last year and in my cars again for this year. I also clip off the balance plug for extra room and add a piece of foam on the bottom for a cushon. I can take a picture tonight with it in there
Tony Newland is offline
Old 02-02-2010, 11:41 PM
Couldn't find Robitronic's pack, but i found a Nosram 1700mah but not the 1500mah.
Already tried this, its tighter than a..."......fill in blanks..."
Old 02-02-2010, 11:49 PM
RC Pro Aus's Avatar
http://www.lrp.cc/en/products/vtec-b...y-74v/details/
Got them in mine last all day long!!!!!!!!!!!!!!
RC Pro Aus is offline
Old 02-02-2010, 11:56 PM
supralative's Avatar
Trader Rating: 16 (100%+)
I use the exact two packs you just posted.
ProTek in the buggy and Reedy in the truggy.
I dremeled the inside of the box to fit the ProTek and put an opening in the side for the balance plug.
For the Reedy I dremeled the plastic piece that holds the throttle servo mount abit, and put an opening for the balance plug also on the side.
I leave my batteries inside all the time, but still open the top to check on them whenever I do a teardown and rebuild. NO issues for over a year on the buggy and half year on the truggy.
I just switched over to digital servos with HRS no longer run a regulator also.
supralative is offline
Old 02-03-2010, 12:20 AM
where can i buy one??
Old 02-03-2010, 08:36 PM
Pic of a Protek 2300 installed..... been running this one for about a year. I didnt dremel anything, The heat shrink has been removed, it fits snug, but its like bolting on a hard case....
http://i470.photobucket.com/albums/r...D8T2010006.jpg
Old 02-03-2010, 11:59 PM
COBRARACING's Avatar
At the end of this month we have the lifep04 batterys 1100mah available for the D8 .we have about 50 as thats all we could get over the chinese new year if you are interested please send us an email and pre order
[email protected]
thank you for your time
COBRARACING is offline
Old 02-04-2010, 12:16 AM
Bigedmond's Avatar
Trader Rating: 20 (100%+)
Try the Reedy 1600
Bigedmond is offline
Old 02-04-2010, 02:45 AM
Tabushi's Avatar
[email protected]
Angelo, Only 1.100mah ?, how much runtime we can squeeze out of them ?, im using on GT Class a 1.450mah one and im very happy ... locally here our a-mains in buggy and truggy are 45 to 60 minutes long, 1.100mah would do it ?
You know im first on the list lol !!, i need 2 batts ...
thanks !
Tabushi is offline
Old 02-04-2010, 06:42 AM
Madbrad's Avatar
Trader Rating: 30 (100%+)
i do 2 qualifiers and a main on my 1100mah. But i guess thats about 25-30 minutes of run time.
Madbrad is offline
