STOCK motor forum
#2417
Originally Posted by dgullickson
F's with red/red or red/purple+
#2418
Originally Posted by DOMOisCOOL
Are the newer CO27's worth it? I want to get a new motor, but my old Monster Stock keeps up with the faster guys in the straight just fine. But it IS getting old (comm is wearing down after cuts, etc etc.).
Still Bill (formerly JRX-S Bill...he, he...)
#2419
guys, i want to buy parma alignment brush hood tool... it can fit to standup and laydown brush hood?
#2420
your choice but i would use the Big Jim's Alignment tool or slide a brush through the hood (while its off the can) and use it to the align the hoods.
-Zac
#2421
Hi everyone,
Have been reading this thread from the beginning, I have a Trinity Monster Stock Pro installed in my losi xxx-s. Have trued the comm, aligned the hood, shimmed the armature, and everything else I could find here and at Hobbytalk forum too. Just can't seem to find the correct gearing for it. The comm always ends up with a dark colored band where the brushes touch the comm. Have tried ratios from 6.75 all to way to 5.9
Using a SX12W with a limit set on the Amps. The straight of the track is only about 100ft
What's the best ratio to use?
Thanks.
Thanks.
#2422
Originally Posted by need4speed
Hi everyone,
Thanks.
Thanks.
#2424
hi, could somebody give me a good gearing start for a corally rdx with a 78spur with the knew co27 stock motor
my local track is short and tight
jordan
jordan
#2425
jordan
jordan
#2426
yer thats what i was gearing at last weekend but i seemed so slow on the track but if i went to a 24 it didnt have enough acceleration
jordan
jordan
#2427
Depending on how short and tight your track is it might have still been overgeared with a 7.0. What are you using for a brush/ spring combo?
#2428
at the min my brush and spring combo is what the motor came with, i dont now if you know the track but it is the coastal model car club in ipswich (uk)
jordan
jordan
#2429
Alright, that track definitely has more flow than I thought from your description. I would first get rid of that stock brush spring combo and use an F brush with purple spring on the positive, and red on the negative. By the looks of the track, as long as your car is decent you should be able to run around a 6.5 ratio, which is what you were running.
#2430
ok thanx for the advise my car is a RDX so i should b kk
jordan
jordan
