Old 08-17-2006, 09:51 PM   #2416
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
Originally Posted by Seano
Can anyone give me a good motor setup, springs, brushes etc for a Co27 and an Epic X to use in TC stock?
F's with red/red or red/purple+
dgullickson is offline   Reply With Quote
Old 08-17-2006, 09:53 PM   #2417
Send a message via ICQ to Seano
Cool, thanks for that Same for a monster also i guess?
Seano is offline   Reply With Quote
Old 08-17-2006, 10:27 PM   #2418
Still Bill's Avatar
Originally Posted by DOMOisCOOL
Are the newer CO27's worth it? I want to get a new motor, but my old Monster Stock keeps up with the faster guys in the straight just fine. But it IS getting old (comm is wearing down after cuts, etc etc.).
Definitely go with the CO27 for racing at RC Tech track in Daly City. Will be killer in the infield.
Still Bill (formerly JRX-S Bill...he, he...)
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-21-2006, 08:49 PM   #2419
nino_pohan's Avatar
guys, i want to buy parma alignment brush hood tool... it can fit to standup and laydown brush hood?
nino_pohan is offline   Reply With Quote
Old 08-22-2006, 02:22 PM   #2420
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
yes it can align both standup and laydown, but mine is tight on the hoods and could possible pinch in the sides. this occurs even when the hood is perfectly aligned.
your choice but i would use the Big Jim's Alignment tool or slide a brush through the hood (while its off the can) and use it to the align the hoods.
-Zac
Z.Hallett is offline   Reply With Quote
Old 08-22-2006, 04:44 PM   #2421
need4speed's Avatar
Hi everyone,
Have been reading this thread from the beginning, I have a Trinity Monster Stock Pro installed in my losi xxx-s. Have trued the comm, aligned the hood, shimmed the armature, and everything else I could find here and at Hobbytalk forum too. Just can't seem to find the correct gearing for it. The comm always ends up with a dark colored band where the brushes touch the comm. Have tried ratios from 6.75 all to way to 5.9
Using a SX12W with a limit set on the Amps. The straight of the track is only about 100ft
What's the best ratio to use?
Thanks.
need4speed is offline   Reply With Quote
Old 08-22-2006, 06:30 PM   #2422
TeamPink91's Avatar
Send a message via AIM to TeamPink91
Originally Posted by need4speed
Hi everyone,
Thanks.
A ratio of 6.75 to 5.9 is most likely way too low for your track. At my local track we are gearing Monsters around a 7.40 with a 80 foot straight.
TeamPink91 is offline   Reply With Quote
Old 08-22-2006, 07:16 PM   #2423
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
WHen the CO27's first hit the tracks, people had to gear up 2-3 teeth on the pinion, even 4 teeth! So start low and work ur way up, Monsters do got alittle more rpm compared to a co27.
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 08-25-2006, 04:35 PM   #2424
hi, could somebody give me a good gearing start for a corally rdx with a 78spur with the knew co27 stock motor
my local track is short and tight
jordan
jordys jrxs is offline   Reply With Quote
Old 08-25-2006, 04:57 PM   #2425
TeamPink91's Avatar
jordan
My local track is 80x50 asphalt and I'm gearing it at a 6.8 to 7.0, which is a 22 or 23 tooth pinion on the corally with a 78 tooth spur.
Old 08-26-2006, 05:07 AM   #2426
yer thats what i was gearing at last weekend but i seemed so slow on the track but if i went to a 24 it didnt have enough acceleration
jordan
Old 08-26-2006, 07:27 AM   #2427
TeamPink91's Avatar
Depending on how short and tight your track is it might have still been overgeared with a 7.0. What are you using for a brush/ spring combo?
Old 08-26-2006, 01:44 PM   #2428
at the min my brush and spring combo is what the motor came with, i dont now if you know the track but it is the coastal model car club in ipswich (uk)
jordan
Old 08-26-2006, 09:31 PM   #2429
TeamPink91's Avatar
Alright, that track definitely has more flow than I thought from your description. I would first get rid of that stock brush spring combo and use an F brush with purple spring on the positive, and red on the negative. By the looks of the track, as long as your car is decent you should be able to run around a 6.5 ratio, which is what you were running.
Old 08-27-2006, 01:02 PM   #2430
ok thanx for the advise my car is a RDX so i should b kk
jordan
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
