Fuel tank leak..can you fix? >
Old 12-27-2008, 01:39 PM
r1harper's Avatar
Trader Rating: 24 (100%+)
Default Fuel tank leak..can you fix?
i got a small leak form my tank Xray 808. i can tank the tank off and plug one end and blow like a mofo on the other and i cannot get a leak to expose itself. as soon as i put it back on da car in a bout a minute i start to see the air bubbles....any ideas? i have had this prob before and was never able to fix it
r1harper is offline
Old 12-27-2008, 01:45 PM
trdsupra88's Avatar
Trader Rating: 25 (100%+)
I would replace the tank or you could be chasing it for a while...
trdsupra88 is offline
Old 12-27-2008, 01:47 PM
r1harper's Avatar
well that normally the case but tanks get expensive....i am definatley gong to get a couple, but would like to try and repair.
r1harper is offline
Old 12-27-2008, 01:57 PM
Trader Rating: 21 (100%+)
I've had good luck fixing leaks with shoe goo, but you've gotta be able to pinpoint where its coming from.
Try immersing it in a sink full of water. Def look at lid and seal, they cause a lot of the leaks. You could just shoe goo the seams - that's where the leaks I've fixed have been if they were not the lid or seal.
Duster_360 is offline
Old 12-27-2008, 01:59 PM
Trader Rating: 66 (99%+)
new tank, without a doubt
pwnzor is offline
Old 12-27-2008, 02:18 PM
jpalessi's Avatar
Trader Rating: 55 (100%+)
R1harper.. are you sure the leak is from your tank? I would check your fuel filter..if you use one...
jpalessi is offline
Old 12-27-2008, 02:35 PM
jamminnay's Avatar
Trader Rating: 11 (100%+)
i would def replace.. i have heard of guys using a soldering iron to fix a leak that is in the seam and that is it.. i would just replace it and be safe!
jamminnay is offline
Old 12-27-2008, 02:38 PM
r1harper's Avatar
no filter...just line and the engine is not leaking either. it started the tale tale signs of a leaking tank so i shut it down. i put it under water and no bubbles, then i put a small line on it and gently put pressure on it with an air com. and with just a little air if i keep the pressure on it the lid will open but i cannot open it by mouth...so i will just get a new one. unless someone knows a way to fix it.
r1harper is offline
Old 12-27-2008, 09:14 PM
LVBaja's Avatar
I had numerous issues with my Losi 8ight tanks for a while. I went through 6 of them in a matter of a couple months. I tried several different methods of sealing them, but nothing seemed to work. I finally sent them back to Horizon Hobbies and they sent me new tanks. Figures that now that I have 5 spare tanks, I haven't had a leak in over 6 months!
LVBaja is offline
Old 12-27-2008, 09:30 PM
imaxx21's Avatar
Wesley, i got some tanks you can have..
email me [email protected]
imaxx21 is offline
Old 12-27-2008, 10:06 PM
r1harper's Avatar
crash i hit you back..thanks
r1harper is offline
