Like Tree130Likes
TA-05 ver.2
Old 06-13-2013, 02:55 PM
  #2341
Originally Posted by nsgland
What track is that?
JP Raceway, Philippines
Originally Posted by k_bojar
how did she do???
TQ and win
rccartips is offline
Old 06-17-2013, 08:19 AM
  #2342
ralph m's Avatar
Trader Rating: 35 (100%+)
Hi Guys, Can you use the TRF shocks for a Mini on a TA05?
ralph m is offline
Old 06-17-2013, 08:54 AM
  #2343
edhchoe's Avatar
Trader Rating: 41 (100%+)
Probably.
edhchoe is offline
Old 06-19-2013, 05:05 PM
  #2344
maxepower's Avatar
Exclamation
I believe the shock body and shaft is shorter than the regular sedan shocks.
just my 2$
maxepower is offline
Old 06-19-2013, 06:28 PM
  #2345
ralph m's Avatar
Originally Posted by edhchoe
Probably.
just my 2$
Thanks guys. I found a V2 with the upgrade parts so I will have the correct shocks but I do have another question: How important is it to have the short arms and 416 uprights that were in the R kit? Worth buying?
ralph m is offline
Old 06-19-2013, 08:51 PM
  #2346
I found a Exotek EX05 Chassis BNIP on eBay and ordered it right away haha. Payed 130 for it which is more than what it sold for from Exotek, but I think it'll be worth it. Stoked to start the transformation of my project TA05.
djtang88 is offline
Old 06-19-2013, 11:22 PM
  #2347
maxepower's Avatar
Exclamation
The 416 arms and uprights are the reinforced plastic which tend not to strip as fast as the softer plastic ones. Although some like the softer Plastic because they will give a little more when you hit and their not as brittle. Plus the plastic ones are a little cheaper!
Just my 2$
Old 06-20-2013, 05:07 AM
  #2348
ralph m's Avatar
Just my 2$
I thought the arms were actually shorter and gave the suspension a different roll dynamic, also required a shorter drive shaft as a result (46mm vs 42mm).
ralph m is offline
Old 06-20-2013, 07:39 AM
  #2349
Jethroz's Avatar
Trader Rating: 54 (100%+)
The TA05v2 and 416 have the same arm length. If you wanted to run a narrow front track using A/A blocks, you will need to go to the 42mm. C/C can use 46mm.
Jethroz is offline
Old 06-23-2013, 11:22 AM
  #2350
does anybody know if the alu gear diff outdrives of a TRF417 fit the TA05 gear diff? I guess only the short version will fit the gear diff, probably the same issue as with a TA06 gear diff.
addicted2blue is offline
Old 06-23-2013, 11:42 AM
  #2351
edhchoe's Avatar
One is for TA05 the other is for 417.
They look to be different although they use the same bevel gear set internally.
edhchoe is offline
Old 07-02-2013, 02:46 PM
  #2352
Stevomatik's Avatar
Is there a big difference between the tamiya "hard black coating" shocks $65 an the tamiya "works team" shocks $80?
Stevomatik is offline
Old 07-02-2013, 03:09 PM
  #2353
FNG RIDER's Avatar
The difference is $15! I have both and can't tell. works may be smoother, cant really tell. so how's you driving?
FNG RIDER is offline
Old 07-02-2013, 08:55 PM
  #2354
Mr Weasel's Avatar
Do you want to sell this to me :P
Where did you find it? do they have any more?
Anybody know where I can get me one of those EX05 Lipo chassis for a V2....?
thanks
Mr Weasel is offline
Old 07-02-2013, 09:12 PM
  #2355
edhchoe's Avatar
Finished 8th out of 37 cars. I managed to get 84 spur and 53 pinion on for FDR of 3.26.
21.5t with HPI D-comp VTA tires.
Red rear swaybar and blue front swaybar.
edhchoe is offline
