Engine sealing.
#16
Put a blob in a small container...then SOAK it in Nitro...see what happens to ur precious RTV....IT MELTS...cuz its not NItro Proof...Trust me it may appear sealed...but ANY leakage and the bond has been broken....Ive seeen SOO many LEAKY RTV sealed motor's its not even funny....1211 or Racer's edge is the ONLY Stuff ill trust....Ive heard of the GM stuff and YamaLube that yamaha tech's use on there motor's......cheesecake thats a decent write up but with the WRONG Sealant....I wish that thread never existed so someone could do a Proper version with the Right sealant.
#17
Don't have to, as I've said used it for years with excellent results. Where it is sealing the parts we're talking about it is not immersed in nitro or a mist of fuel. I understand what you are saying, but sealing an engine and soaking it in nitro are two different horses. I guess we both agree to disagree, no harm in that.
#18
I've never had to seal ANY RB, NovaRossi, Lamberto collari (works), Rex, TOP, Mugen, OS motors EVER. The only motor I have ever owned that needed sealing was a Pico (carb). Buy good motors & the only time they will leak is if an O-ring has been damaged or worn out.
#20
Just put some regular sealer its red worked no leak but I'm still gonna get the racers edge stuff.
#21
I had to seal both my C6 and my OS 28... I find sealant like 1211 makes a better seal then just a o-ring or gasket alone will.. these mills operate on crankcase pressure and the better sealed the engine is the more efficiently it can run..... I know most motors really do not need to be sealed, they will operate quite fine without being sealed... but without a doupt only good can come from sealing an engine.. maybe a o-ring will make a 100% seal, or maybe it will make a 95% seal, i can guarantee sealant will make a 100% seal every single time..its easy to apply. its also easy to cleanup...its a win win situation any way you look at it.
#22
HAH...I got proof that Just because u Spend Big $$ on a motor does NOT mean it wont have any leaks....Purfect example....Buddy's BRAND new Os Speed....Leaked like a Siv out at the nats....backplate...carb...pinchbolt.....the motor was Blatently wet compared to the rest of the mills and thats 1 of the most expensive race mills u can buy....Big money Does not = Purfect performance.
#23
PURRR fect
#24
whether it makes a difference or not, but I do run and live in a very cold climate... I also run in weather that is sometimes below freezing.. I find i have to seal pretty much every engine I run regardless of manufacturer...
#25
Tech Prophet
dont have to seal novarossi engines . i have never once had a problem with a leaky crank case in any novarossi engine , if you feel it necessary then thats fine ,all that i am saying is that i dont do it and havent had to in over 100 engines that i have built and or maintained . just make sure your orings are in good shape and put a little oring safe oil on all of them before you put the engine together and its all good .
monty
and i am not really for or against using air seal , if you do choose to use air seal i am sure the product peter at TKO is coming out is going to be the goods !!!
monty
#26
By the end of next week TKO will have the identical formula as the,no longer, Racers Choice Air Seal in stock.
www.tkocompetitiondev.com
#27
