Tamiya TB-Evolution III
#2836
ooo nice! i wanna get some of those...i'll check R10
#2837
#2838
they better hav blue in my LHS's! i wouldn't get red if there was it...would totally look bad!
#2839
Look what rainbowten has in stock
#2840
thanks for the pic
#2841
What do you have to pay for shipping some parts @ rainbowten?
#2842
#2843
Hey everyone,
I just ordered my Surikarn Evo 3!!!! Is there any thing I should know about the car? I can probably get tuning tips from Difuser or Peter because I race with them all the time . I'm more worred about the durability of the front one way gear. Is there any way to make it any better? Thanks.
-Sushi Boy
-Sushi Boy
#2844
Originally posted by Sushi Boy
Hey everyone,
-Sushi Boy
Hey everyone,
-Sushi Boy
Ok I'll try to keep this short and striaght forward
All you'll need is two of the standard Assoc Bevel Gears for there box. You do need to change both because of final drive ratio. Which after the modification chg's from 2.6 to 2.667.
On a diff the assoc gear and balls are slightly narrower. so what you'll want to do is . . . . On the diff half that holds the second inter bearing use a dremel (?) and carefully make the current bearing hold just slightly deeper - not very much. If you don't do this enough you'll not be able to tighten the diff correctly.
On the front one way - all that is needed is to enlarge the hole to just fit on the one way unit. The current ball holes on the assoc gear line up perfectly to screw the gear on. I had made a graphite backing plate and am still using it.
The pinion you'll use is the standard tamiya one.
The last thing is the assoc gear messes better with the pinion and results in excess for and aft play on the drive shaft. I would suggest a spacer that is placed between the bearing on the rear box and the spur gear. This will tend to push the shaft forward to increase the "flat" spot surface area used in the pinion.
Hope this helps
The Assoc gears are $7 US each - the white material ones are stronger than the black material gears. Either work however.
#2845
it was rocketron, give him the credit if you use that mod.
#2846
Originally posted by GTMilenko
someone(sorry forgot his name) posted a good little gear mod a couple of pages back. anyway i copied and pasted it for my own use. so here it is again. i haven't tried it yet but he says it works great.
Hope this helps
Hope this helps
#2849
Just found the electronic version of the blank setup sheets for the EVO 3 Surikarn Edition.
EVO 3 S Blank Setup sheet
Tony
Tony
#2850
FAT EVO III
Fat evo III, by KAI although i dont think looks so good preety curious how it will handle
KAI EVO III FAT VERSION
