Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 10-30-2017, 11:00 AM
  #14476
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Jeff Werner
New to the RB6.6. Raced it this past weekend. Really enjoyed it. I built mine with the 3 gear laydown. I have seen a ton of setups and they mostly look to have the 4 gear standup in the buggy. I would like to have my buggy produce some more rear traction and did not know if racers are running the 4 gear in 17.5?
I am running 3 gear in my 17.5 car. What type of track and compound of tires are you running?
Kraig is offline
Old 10-30-2017, 11:55 AM
  #14477
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
We are medium to high bite clay. Gold or Clay compound tires. Slicks or Ghosted treads are usually the ticket. I started with Tebo 2017 Fastlane Setup with the V2 front towers since I bought them for the buggy.
Jeff Werner is offline
Old 10-30-2017, 05:02 PM
  #14478
Can someone give me an idea for gearing with a 10.5? I've been running a 13.5 with 29/76, so I'm guessing around 27/78? Am I in the ballpark?
heyscottn is offline
Old 10-30-2017, 05:28 PM
  #14479
Super Moderator
Kraig's Avatar
Jeff, this is what I ran this past weekend. I tend to have a smooth driving style and I don't saw the wheel but rather turn it as much as I need to.
Attached Thumbnails Kyosho Ultima RB6 & RB6.6 Car Thread-kraig_race_em_rockford.png
Jeff Werner likes this.
Kraig is offline
Old 10-30-2017, 07:37 PM
  #14480
Can you explain what you are doing with the waterfall? You run the laydown tranny?
Thanks for the setup.
Old 10-30-2017, 09:12 PM
  #14481
hairymuffin's Avatar
Trader Rating: 105 (100%+)
I think he is saying, he trimmed the nubs on the waterfall, it lets you move the battery back a few more mm’s
Kraig likes this.
hairymuffin is offline
Old 10-31-2017, 10:48 AM
  #14482
Super Moderator
Kraig's Avatar
Correct, three gear laydown. Hairymuffin is correct in what I did.
Kraig is offline
Old 10-31-2017, 01:59 PM
  #14483
Originally Posted by 76jimmy
I ordered one for my son. Definitely post up what you find with the rtr.
Sorry for the delayed response. I only managed to get a single battery pack of practice laps in this weekend due to a full schedule but, overall, I'm impressed.
It's crazy how much technology has improved in the last 15-20 years of RC.
Some additional comments:
1. The stock tires were practically useless on the hard packed clay. I knew they would be bad, but the buggy was almost uncontrollable. I let a seasoned driver have a go and got the same feedback, the rear just kept stepping out. Based on the recommendation of folks at the track, I picked up a set of appropriate tires and the buggy was immediately more hooked up.
2. I had a dog bone pop out on a light crash. Not a big deal, just popped it back in and was off again.
3. I had one shock come apart and spill oil over the track. This was a good opportunity to check and refill the oil on all the other shocks to make sure they were toped up.
4. The buggy currently tends to nose dive a bit on jumps. I can correct this slightly with throttle inputs, but it still seems excessive. Need to tune this out. Any suggestions from the experts?
Overall it was a blast, though I have a long way to go before I can lay down consistent laps.
SpeedDog is offline
Old 10-31-2017, 02:17 PM
  #14484
CHeck your ride height for nose diving. Set to 24mm f/r to start. Hard to say where to start with oils since I don’t know what pistons
eper likes this.
Old 11-04-2017, 06:35 PM
  #14485
Trader Rating: 18 (100%+)
Default 17.5
I run at “The Track” where the roar nats where hosted. I am running tebos setup and it’s very good. But I’m switching over to 17.5 stock racing so I have to make some weight changes. Would anything setup wise change because use I’m running 17.5 versus mid? So far the only piece I removed from his setup is the rear front brass block and put the aluminum one in its place to save weight.
Any help or thoughts would be greatly appreciated.
Thank you
Ben
BensPro2 is offline
Old 11-04-2017, 07:21 PM
  #14486
Super Moderator
Kraig's Avatar
Ben, I would start with .5 degree less toe and try a 3 gear transmission setup. I personally like the brass block with the 3 gear transmission in 17.5.
Kraig is offline
Old 11-04-2017, 08:21 PM
  #14487
alex4r's Avatar
Trader Rating: 12 (100%+)
I use the 3-gear lay down with brass RF block in 17.5 too. I was able to save weight in other places to make up for it (Exotek eliminator, carbon composite parts, and Ti turnbuckles).
alex4r is offline
Old 11-05-2017, 06:39 AM
  #14488
Default Info
Thanks guys. I’ll start with the 3gear lay down and put the brass block back in. From there I will see where I can save weight. I am already using the JTP front and rear towers and battery strap.
BensPro2 is offline
Old 11-05-2017, 06:44 AM
  #14489
Default Gearing
What gearing are you guys using? I have 31/69 in there now.
BensPro2 is offline
Old 11-05-2017, 07:19 AM
  #14490
alex4r's Avatar
Depending on the traction level and what tires I'm using, I gear between 30-32 with a 69t spur.
alex4r is offline
