Tekin T8 Motor Q & A for ALL systems >
Old 05-04-2009, 08:22 AM
  #31
RBMike's Avatar
The revision date on that link is 5/7/08 & it says nothing about the RX8. Am I missing something?
RBMike is offline
Old 05-04-2009, 08:29 AM
  #32
Cain's Avatar
Trader Rating: 294 (100%+)
For this motor, if you are running in Hybrid or sensored mode (not sure if the latter is available), if for some reason the sensor cable gets knocked free, does this damage the ESC or motor? I have heard that other sensored setups in 1/10 scale seem to get damaged if the sensor wire gets unplugged for some reason.
Also, have the same question about the LVC that someone else posted, as to when it will be able to be manually set to a custom level.
Cain is offline
Old 05-04-2009, 08:34 AM
  #33
J Drye's Avatar
Both the RX8 and RS Pros can be run sensored or sensorless they are made to where if the sensor comes unplugged you are still able to keep running in sensorless mode.
The LVC can be manually set on the RX8 if you use the hotwire.
J Drye is offline
Old 05-04-2009, 08:39 AM
  #34
Cain's Avatar
great. So for LVC I can set 12.8V? Where do you go in the software to do that as the pic I saw i didn't see anything that stood out for that like the Losi or Castle interfaces.
Cain is offline
Old 05-04-2009, 08:52 AM
  #35
J Drye's Avatar
Here is a pic for ya to see it, the LVC is the 7th column from the left.
Last edited by J Drye; 05-07-2009 at 10:27 AM. Reason: changed location of pic in photobucket
J Drye is offline
Old 05-04-2009, 09:41 AM
  #36
Cain's Avatar
great! thanks!
Cain is offline
Old 05-04-2009, 09:58 AM
  #37
Hi,
Which T8 BL motor along with RX8 esc do you recommend for a RC8 on 4S?
Tracks here are kinda big,so I was thinking of 2050,with 15 or 16 tooth pinion.
Let me know your opinion.
Thanks in advance
afonsospt is offline
Old 05-04-2009, 02:29 PM
  #38
Depends on how long your mains are. A 2050 on 4S 5000mAh may or may not make a 15 min race. A 1900 should make it more easily. Either should be able to be geared to be fast enough.
Stealth_RT is offline
Old 05-04-2009, 06:30 PM
  #39
Team Tekin
Randy_Pike's Avatar
For larger tracks I tend to reach for the 2050 if the traction is average. If the track is slippery or smaller I go for the 1900.
Both are great choices for 4s. For most tracks the 1900 can get it done. Ty and Jim and myself all ran the 2050 at Silver State and felt it was great. I was only putting 3400 or so back into our 4s packs after a 12 minute main with 3 warm up laps.
Randy_Pike is offline
Old 05-04-2009, 06:31 PM
  #40
Team Tekin
Randy_Pike's Avatar
Originally Posted by bradfox2
Randy
i remember you said something like for every 10 on hotwire, it is a 3 degree increase. Is that right?
Brad, Yes. The Timing Advance slider is a percentage of 30 degrees.
Old 05-04-2009, 06:37 PM
  #41
B.A. Racer's Avatar
im gonna be buying a tekin motor and esc for my rc8e and was wonderin what setup u guys run with it...wat motor with wat battery and which gearing..and how long does it last?
B.A. Racer is offline
Old 05-04-2009, 10:31 PM
  #42
wpr2's Avatar
Trader Rating: 13 (100%+)
For my RC8e I got the Tekin 2050kv motor and am running it with 2 thunder power 5000mah 40c's. And the gearing was 16/46 and I didn't time my runtime yet but I would say I get about 14-15 minutes on a medium sized track, but I am very pleased with the combo for the track I run at.
Alex
wpr2 is offline
Old 05-05-2009, 03:50 PM
  #43
B.A. Racer's Avatar
so a 2050kv is prolly the best way to go with tekin? does it has good speed and acceleration..cuz i think the 2650kv is way to much
Old 05-05-2009, 05:41 PM
  #44
AMZ
AMZ's Avatar
Tekin,
What exactly does the 1,1.5,2,2.5,3 and Y/D designation refer to?
AMZ is offline
Old 05-07-2009, 07:31 PM
  #45
Team Tekin
Tekin Prez's Avatar
Number of turns of wire and how they are connected in a Y configuration or a Delta (star). Lower turns are more more powerful and faster typically and delta winds are more powerful for the same number of winds.
Tekin Prez
Tekin Prez is offline
