HPI R40 Nitro Car Forum
#4456
ok, the only problem is the wires bulge the battery cover out a little bit but that doesnt matter. Cant wait till race season!!!!
Later
Later
#4457
Nitroracer I ran my cables around the batery case and into the receiver box, since I have a small kopropo receiver they fit in nicely. try it.
Where did you get the r-40 kit with al the hop ups?
I still need to buy the chasis, the .08 LW 2 speed and the titanium screws and pivot ball
#4459
That battery case sucks Mine didnt keep out any gas so I just took it off and rubber cemented it to the bottom of the box.
#4460
klanderman- I bought the car used from a guy at the hobby shop. Its in great condition so how can I say no. I think Il will run the wires around the battery pack, its a good idea.
Later
Later
#4461
spiders
Originally posted by HarKonnenD
They look the same to me. I called the LHS guy and he said they are the same, but I'll check for sure when I get there.
#4462
WEIGHT REDUCTION!!!
Like I said before, There are a lot of weight reduction parts out there in the market, I have a couple, but which ones are the really important ones to get???
Can anyone tell me the weight of your car with everything except nitro fuel?
Mine weighs 1932 grams....
Graphite F/R shock towers
Graphite belt tensioner
Graphite steering brace
titanium 2 speed shaft
titanium front shaft etc...
#4464
Where can I buy the one piece motor mount?
#4465
What's the weight difference between the normal 2 speed tranny and the LW 2 speed tranny?
I know the chasis weighs 20 grams less than the stock, and the titanium screw weigh 40 % less than stock...
#4466
Aside from being lighter it was said the LW 2speed has a smaller pitch and you will notice a higher top end speed. It also allows a larger selection of gearing I believe. Gonna get mine in a little bit at the LHS along with the LW shafts and other stuff. What's everyone running for diff oils if using the stock gear diffs?
#4467
Harkonnen Im using light grease in the rear diff case and I have a oneway bearing infront.
I'll probably get the LW chasis first... then the 2 speed an later the titanium screws...
#4468
Does anyone know with the stock configuration how fast is the r-40 with: let's say a .12 novarossi engine running around 35,000 to 38,000 RPM's, novarossi pipe just as an example?
#4470
smoke
1 queston from a new r40 owner.
The carbon fiber side flex brace is the piece by the belt with the belt tensionizer, right?
