Old 02-16-2005, 05:54 PM   #4456
ok, the only problem is the wires bulge the battery cover out a little bit but that doesnt matter. Cant wait till race season!!!!
Later
nitroracer20 is offline   Reply With Quote
Old 02-16-2005, 10:43 PM   #4457
KLANDERMAN's Avatar
Nitroracer I ran my cables around the batery case and into the receiver box, since I have a small kopropo receiver they fit in nicely. try it.
Where did you get the r-40 kit with al the hop ups?
I still need to buy the chasis, the .08 LW 2 speed and the titanium screws and pivot ball
KLANDERMAN is offline   Reply With Quote
Old 02-16-2005, 10:43 PM   #4458
Send a message via AIM to racer034life
ok i have got it done to two nitro cars the r40 and the Ntc3 which car is tuner friendly and which car is easy to race and work on for a send time rc car and a first time nitro drive
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 02-17-2005, 04:27 AM   #4459
nsxshogun's Avatar
Send a message via AIM to nsxshogun
That battery case sucks Mine didnt keep out any gas so I just took it off and rubber cemented it to the bottom of the box.
nsxshogun is offline   Reply With Quote
Old 02-17-2005, 04:46 AM   #4460
klanderman- I bought the car used from a guy at the hobby shop. Its in great condition so how can I say no. I think Il will run the wires around the battery pack, its a good idea.
Later
Old 02-17-2005, 06:55 AM   #4461
billysss's Avatar
Default spiders
Originally posted by HarKonnenD
They look the same to me. I called the LHS guy and he said they are the same, but I'll check for sure when I get there.
r40 spider gears and savage are the same, THIS IS A FACT, i use them interchangeably. When i damage the savage gear, i use teh r40 as spares.
got to race...and temporarily forget the mess we're in...
billysss is offline   Reply With Quote
Old 02-17-2005, 07:42 AM   #4462
KLANDERMAN's Avatar
Default WEIGHT REDUCTION!!!
Like I said before, There are a lot of weight reduction parts out there in the market, I have a couple, but which ones are the really important ones to get???
Can anyone tell me the weight of your car with everything except nitro fuel?
Mine weighs 1932 grams....
Graphite F/R shock towers
Graphite belt tensioner
Graphite steering brace
titanium 2 speed shaft
titanium front shaft etc...
Old 02-17-2005, 08:17 AM   #4463
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Front and rear towers
.8 two spd
light shafts
side flex brace
? one peice motor mount beter rpm's
chassis if you wan't to spend the money
that's all you need for beter handeling and performance
one car is 1850 or so and the other is 1900 or so
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-17-2005, 08:27 AM   #4464
KLANDERMAN's Avatar
Where can I buy the one piece motor mount?
Old 02-17-2005, 08:38 AM   #4465
KLANDERMAN's Avatar
What's the weight difference between the normal 2 speed tranny and the LW 2 speed tranny?
I know the chasis weighs 20 grams less than the stock, and the titanium screw weigh 40 % less than stock...
Old 02-17-2005, 12:22 PM   #4466
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Aside from being lighter it was said the LW 2speed has a smaller pitch and you will notice a higher top end speed. It also allows a larger selection of gearing I believe. Gonna get mine in a little bit at the LHS along with the LW shafts and other stuff. What's everyone running for diff oils if using the stock gear diffs?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-17-2005, 02:15 PM   #4467
KLANDERMAN's Avatar
Harkonnen Im using light grease in the rear diff case and I have a oneway bearing infront.
I'll probably get the LW chasis first... then the 2 speed an later the titanium screws...
Old 02-17-2005, 02:18 PM   #4468
KLANDERMAN's Avatar
Does anyone know with the stock configuration how fast is the r-40 with: let's say a .12 novarossi engine running around 35,000 to 38,000 RPM's, novarossi pipe just as an example?
Old 02-17-2005, 03:12 PM   #4469
20 SMOKE's Avatar
The motor mount I think is a Hara product
stock two spd to .8 two spd with any nove .12 your talking about 3 or 4 mph
go with the .8 before the chassis
Jamie W
Old 02-17-2005, 03:18 PM   #4470
Default smoke
1 queston from a new r40 owner.
The carbon fiber side flex brace is the piece by the belt with the belt tensionizer, right?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
