TA-05 ver.2
#227
hey everyone, is the aluminum gear box (53990) a recomended hop up for the ta05v2?i was just wondering because the stock gearboxes seem rather weak.
thanks guys
thanks guys
#229
Super Moderator
No, the main chassis is different too, it's narrower, & that also means the chassis braces have to be different too. Also, the new chassis is meant to use the new seperated suspension mounts, while all the older versions are not. So we'll just have to wait for Tamiya to release new carbon-filled parts(which I expect shouldn't take too long).....
#231
and with the 3r chassi you get the braces and everything. so steering and the seperated sus mounts should be the only thing that dont fit.
was thinking of getting the ver2 or converting my ifs r but went for a 416we instead.
#232
My verII is ready running on 5.5T Brushless. Can anyone help me out on the option parts etc TBO3,TR415,416 for upgrade on my VERII? Am eager to put on option parts as soon as possible and i will update you on its performance on drifts as well.
My Ride: TA05 VerII, TT01D, TT01, HPI E10, Lightning
#234
shock spring
kit original shock spring, is it good?
If change to onroad spring set, what color to use fr/rr? what the spring rate compare to the stock one, it is softer/harder?
#236
Super Moderator
Hi need some info from you guys. Do you guys insert an O-ring(black color) on the ball connector for the damper? If yes does it apply the same thing on all the turnbuckle ball connector also? Thks!
#240
Pls help! Everytime I enter a corner the car rear since to keep on spining out. What may cause this? Thks!
