Tamiya TRF2WD thread
#2326
He means one trailing, one not, by accident!
I too am wondering what setup difference it makes, I need more mid/on power steering and was wondering what trailing arm and castor would work best?
#2328
Thanks for all the reply, now i did a step forward to understand what we are talking about, but i still have some doubts and questions.
I understood that the TRF201 has a "Trailing Axle" configuration, with the axle "behind" the kingpin.
I still have to understand how to deal on the "Trailing axle" configuration and what results should i expect moving to F or R (i have to move the 2 plastic washers...?) i suppose that the car in std config is on the "0", am i correct?
This is what i see on the Set Up Sheet on the "Trailing Axle" setting.
I race my car mostly on dirt dry dusty low traction tracks and i'm really happy of my car set up (thanks Lee...... ), but this is something i never saw changed on "Pro" sheets (proabably there is a good reason... ) and for this reason i never dedicated too much attention to it, but now i'd like to learn a little bit more.
Thanks a lot for your attention and help.
Bye
WWD
Bye
WWD
#2329
btw, i have switched both to inline now
#2330
Bye
WWD
Bye
WWD
#2331
Here what i changed:
- I use less weight only 45gr under the servo
- Green tamiya springs at front instead of yellow
- No front wing (just because i don't have one but i'll try one soon)
- Rear tyres: Losi big Shots (Red) or Jconcepts Double Dees (Green) or Pro Line Hole Shots (M3)
- Front Tires: Losi Rib Tyres 7202 or 7205 (Silver) or Jconcepts Groovy (Green).
That's it and i'm very happy with it since i like "light" car set up but i'm still working on it.
Bye
WWD
#2336
What tires are you running? I'm on Bar Codes right now.
