New Chassis Setup App - Have you tried it? >
Old 01-27-2012, 05:21 AM
  #271
cwoods34's Avatar
Originally Posted by Edwin Pibal
Hi Martin
thank you for the reply thats plenty to try thanks!, i plan on getting a iPhone sooner than later.
a silly question about the roll centres if i may.
the tc6 link mounts are like this x = mounts on the shock tower
xx xx x x xx xx
xx xx
xx xx
currently mine are set like this 0 = where ball joints are
x0 x0 x x 0x 0x
xx xx
xx xx
when you say raise the roll centres where would i go too ? the inter outer top hole ? till now i have been useing the inner most long link and have liked it, but for these tires it doesnt work
or should i shart by bringing the bottom suspention arm mount up abit ?
thanks for your time
Ed
ps, feel free to come over to New Zealand! we would love to have you here!
Don't mean to interject, BUT.....
For low bite, try 3* rear toe-in and run 1B rear arm blocks. I've tried this a couple of times and it keeps the back end very stuck..... I like 0B front arm blocks with this. I also run the rear link at 3A, with silver ballstud and 1mm shim under it. Hope this helps!
cwoods34 is offline
Old 01-27-2012, 08:18 PM
  #272
thank you!
ill give it a shot too.
what camber do you run -1.5ish and do you run the long links up frount or the short ones there too ?
thanks again
ed
Edwin Pibal is offline
Old 01-27-2012, 10:16 PM
  #273
cwoods34's Avatar
Short links front and rear, wound up at -1.0 camber all around!
cwoods34 is offline
Old 01-31-2012, 11:56 PM
  #274
TryHard's Avatar
Hi Martin,
Question time for you... what are your thoughts on how shock position affects damping rate?
Now, I know that moving the postions out on the arms effectively stiffens the shock up in terms of spring rate, so I am assuming it has a similar affect on damping rate as well... in effect making a damper that is mounted further out on an arm have a heavier oil.. is this right, or is damping rate not so affected, being as it is more to do with rate of change (how fast the piston moves) than anything else?
Be interested to hear your thoughts, I'm trying to figure something out for my new car..
Cheers
Ed
TryHard is offline
Old 02-01-2012, 02:37 PM
  #275
Martin Crisp's Avatar
Originally Posted by TryHard
Hi Martin,
Cheers
Ed
Hi Ed,
Interesting question. I am fairly certain that the angle of the shocks in no way affects the dampening rate like it does affect the effective spring rate.
I hope that helps.
Martin Crisp is offline
Old 02-02-2012, 01:02 AM
  #276
TryHard's Avatar
Originally Posted by Martin Crisp
Hi Ed,
I hope that helps.
Hi Martin,
Thats what I was thinking as well, but then talked myself into it as the piston is connected to the shaft, which is attached to the arm... so moving the position could change the rate the piston moves through the oil... i.e. further out, moves slower, so can run softer oil... maybe...
Cheers
Ed
TryHard is offline
Old 02-02-2012, 09:52 AM
  #277
Jim Frahm's Avatar
Trader Rating: 68 (100%+)
Hi Martin,
Cheers
Ed
Actually it doesn't matter what the angle of the shock is with respect to the damping. The oil is resisting the motion of the piston and it's constant throughout the piston travel. The springs on the other hand do increase resistance the more you compress them. Jim
Jim Frahm is offline
Old 02-05-2012, 09:16 PM
  #278
tried this at our Nationals this past weekend and yeap!, it worked a treat
it was the nut behind the wheel and the the expireing motor that hampered me.
so thank you for shareing that setup info with me
Ed
Old 02-07-2012, 05:58 AM
  #279
Ed
good stuff....well except for the expiring motor
I know what you mean about the nut behind the wheel...I felt that way after a couple of runs at the snowbirds last week. Also I took a gamble on my a main setup that made the car worse....I will have to fire my mechanic
Old 02-07-2012, 12:38 PM
  #280
Send your Mechanic to New Zealand!
sounds like he needs a racing holiday
Old 02-07-2012, 11:44 PM
  #281
Benzaah's Avatar
Trader Rating: 24 (96%+)
Martin, on shocks and angles. Ive got the S411 and im unhappy with the wear on the shock ends with my soft Sorex rims rubbing excessively under a flexed load. I have the shocks outside hole on the arm and position 5 on the tower. Could you suggest a similar position on the tower if i have the inner hole on the arm used. Springs currently are Orange front, yellow rear with 550cst front and 450cst rear oil. I have the black and grey springs but im waiting for the green to come in stock here before i try them as it has been suggested to run green/grey on asphalt.
Regards Benzaah.
Benzaah is offline
Old 02-08-2012, 07:18 AM
  #282
Regards Benzaah.
If you go in one hole on the arm, try going to hole 6 on the tower as a first step. An alternative approach would be to keep it in hole 5 and then lay down the front shocks one holed on the tower. I currently use hole 4 on the tower and the inside hole on the rear arm when using grey springs front and rear, with the front using the outside hole on the arm and position 3 on the tower.
Old 02-14-2012, 06:16 PM
  #283
just in case you are interested in a post I just made on the serpent thread about setup. http://www.rctech.net/forum/electric...l#post10329274
Old 02-21-2012, 04:43 PM
  #284
Skiddins's Avatar
Hi Martin.
Can you think about adding a section on Bump Steer in future revisions?
Is there some way that some of the settings can be explained with how they react to low or high grip etc.
Hmm there's no easy way to put this, err, but perhaps, hmm, the use of a spell checker as well
Skiddins
Skiddins is offline
Old 02-22-2012, 07:07 AM
  #285
Originally Posted by Skiddins
Hi Martin.
Skiddins
lol...yeah...I know there are too many typos in the app Believe it or not, I used spell check and had other read it...but still there remains too many typos
Bump steer is certainly something I will add in the future.
I think a section talking about how to approach low and high grip tracks is also a good idea for sure.
Thanks for the feedback.
Cheers.
