Team Corally RDX Touring Car
#8491
Originally Posted by sohlman
Does anyone have any suggestions on a 19T asphalt setup? Here's my setup from last weekend. Felt great but I was dragging the chassis in the high speed corners. Also, the rear was a little loose coming out of 180s on the power. Thanks in advance.
#8492
With the new arms and 2 hole narrow rear uprights, what settings would you use to keep the rear of the car equal to the old arms with the shocks all the way out on the standard extensions? I want to get the added strength of the new arms without changing my setup so I can get a feel for how different they might feel, if at all.
Hopefully some of the new stuff gets run in Vegas. The setup sheets you guys provide are invaluable, but they're starting to get a little bit outdated with all the new parts that are coming out and being used. I'm especially curious about the new shock pistons, and Jeff's earlier prediction about people going back to 1.1 and .9 for carpet.
#8493
new arms and toe
The original release of the new arms had 1 degree of toe by default for the rear arms... can someone confirm if the current release of new arms still has this 'feature'?
#8494
Another quick (New Arm) Question.
Does the new arms alter the wheel base length in comparison to the old ones?
Cheers
Scott
Cheers
Scott
#8495
The setups are not really outdated, they are fast and win. We just have new options we need to test to see what will work. I am planning putting the 1.1mm pistons in my car for Vegas.
Jeff
#8496
Jeff
#8497
Cheers
Scott
Cheers
Scott
Jeff
#8499
Hot in FL, surely you jest
#8500
#8501
Jeff,
Can you post an updated setup sheet on the Corally USA website that has the hole positions on the new arms? I still get cross-eyed looking at the old setup sheets.
Many thanks.
Bill
Many thanks.
Bill
#8502
#8503
Originally Posted by EAMotorsports
Jeff Brown with the answers to all questions!!
It hot down there yet?
EA
EA
Jeff
#8504
Originally Posted by JRX-S Bill
Jeff,
Many thanks.
Bill
Many thanks.
Bill
The new arm holes are as follows..........
Outside = X-long SRC extension
Middle = Standard extension
Inside = No extension on old arm
The front arm holes are as follows......
Outside = new 4th hole
Inside = outside hole from old arm
Jeff
#8505
And just to clarify, with the new arms and new 2 hole narrow rear hubs on the inside hole, we will need to use the regular hexes to make width and not the narrow ones? With the new front arms, the shimming/hex combo stays the same to make width, right? I guess I could just lay the arms on top of the others like someone said, but it's good to get it out here for everybody else to see.
Thanks for the info Jeff. The current setup sheets are great, it's just getting a little more tricky now with all the new options.
