Old 08-16-2006, 09:30 AM   #8491
Trader Rating: 18 (100%+)
Originally Posted by sohlman
Does anyone have any suggestions on a 19T asphalt setup? Here's my setup from last weekend. Felt great but I was dragging the chassis in the high speed corners. Also, the rear was a little loose coming out of 180s on the power. Thanks in advance.
You should try Jeff Brown's asphalt set up available at www.corallyusa.com. It is an awesome starting point and possibly could be what you are looking for. Try it as written, then after you are comfortable with it change it to suit you.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 08-16-2006, 06:09 PM   #8492
syndr0me's Avatar
Trader Rating: 32 (100%+)
With the new arms and 2 hole narrow rear uprights, what settings would you use to keep the rear of the car equal to the old arms with the shocks all the way out on the standard extensions? I want to get the added strength of the new arms without changing my setup so I can get a feel for how different they might feel, if at all.
Hopefully some of the new stuff gets run in Vegas. The setup sheets you guys provide are invaluable, but they're starting to get a little bit outdated with all the new parts that are coming out and being used. I'm especially curious about the new shock pistons, and Jeff's earlier prediction about people going back to 1.1 and .9 for carpet.
syndr0me is offline   Reply With Quote
Old 08-16-2006, 06:51 PM   #8493
Big Rigg's Avatar
Default new arms and toe
The original release of the new arms had 1 degree of toe by default for the rear arms... can someone confirm if the current release of new arms still has this 'feature'?
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 08-16-2006, 07:00 PM   #8494
SJP
SJP's Avatar
Another quick (New Arm) Question.
Does the new arms alter the wheel base length in comparison to the old ones?
Cheers
Scott
SJP is offline   Reply With Quote
Old 08-16-2006, 07:22 PM   #8495
Jeff Brown's Avatar
Well, the inner hole on the new arm is the stock position for the hingepin. If you put it in the outer hole you will quickly find the CVD's are not long enough. I am building a new car for Vegas and I will probably put the new arms on with the hubs.
The setups are not really outdated, they are fast and win. We just have new options we need to test to see what will work. I am planning putting the 1.1mm pistons in my car for Vegas.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 08-16-2006, 07:23 PM   #8496
Jeff Brown's Avatar
The new arms never had toe built into them from everything I understood. It would not make sense to do that. The latest batch we received should be straight as well.
Jeff
Old 08-16-2006, 07:23 PM   #8497
Jeff Brown's Avatar
Cheers
Scott
No, they do not.
Jeff
Old 08-16-2006, 07:38 PM   #8498
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Jeff Brown with the answers to all questions!!
It hot down there yet?
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-16-2006, 07:43 PM   #8499
Rainman40's Avatar
Hot in FL, surely you jest
Rainman40 is offline   Reply With Quote
Old 08-16-2006, 07:52 PM   #8500
Still Bill's Avatar
Just lay a new front or rear arm on top of an old style arm to see the differences in the placements of the holes. That should show you the way.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-16-2006, 07:57 PM   #8501
Still Bill's Avatar
Jeff,
Can you post an updated setup sheet on the Corally USA website that has the hole positions on the new arms? I still get cross-eyed looking at the old setup sheets.
Many thanks.
Bill
Old 08-16-2006, 08:37 PM   #8502
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
can anyone else comment? i have experienced this also. I was running the 2 degree hubs -and for some reason.... had 3 degrees of toe with equal shimming on the front and back arm mount.
signature'd
|<R1Z |> is offline   Reply With Quote
Old 08-16-2006, 08:45 PM   #8503
Jeff Brown's Avatar
EA
Hot........ Hot?! LOL...... I don't leave the shop during the day.
Jeff
Old 08-16-2006, 08:49 PM   #8504
Jeff Brown's Avatar
Originally Posted by JRX-S Bill
Jeff,
Many thanks.
Bill
I'll try and work on that. The setup sheets are created overseas usually but I could probably do it. The problem now is will everyone be using the new arms? haha.
The new arm holes are as follows..........
Outside = X-long SRC extension
Middle = Standard extension
Inside = No extension on old arm
The front arm holes are as follows......
Outside = new 4th hole
Inside = outside hole from old arm
Jeff
Old 08-16-2006, 09:07 PM   #8505
syndr0me's Avatar
And just to clarify, with the new arms and new 2 hole narrow rear hubs on the inside hole, we will need to use the regular hexes to make width and not the narrow ones? With the new front arms, the shimming/hex combo stays the same to make width, right? I guess I could just lay the arms on top of the others like someone said, but it's good to get it out here for everybody else to see.
Thanks for the info Jeff. The current setup sheets are great, it's just getting a little more tricky now with all the new options.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
