Like Tree207Likes
Mugen MRX6
Old 02-01-2019, 08:41 PM
  #841
Kevin CBR's Avatar
Trader Rating: 11 (100%+)
Kevin CBR is offline
Old 02-05-2019, 07:45 PM
  #842
banana rt's Avatar
anyone using drag brake ?
any advice for how much % should we use,
thx
banana rt is offline
Old 03-20-2019, 08:23 AM
  #843
sinisterRC's Avatar
Hey fellas,
Anyone have any tips on removing the rear sway bar efficiently?
Also, what are the benefits of running the discs on the uprights?
Thanks!!
sinisterRC is offline
Old 03-20-2019, 08:26 AM
  #844
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Remove one tie rod/link to the sway bar, would be the quickest way to render it inoperable.
But why are you asking to do this?
1/8 IC Fan is offline
Old 03-20-2019, 09:36 AM
  #845
I don't think he wants to take it off, I think he's looking for an easier way to change them.
nitrodude is offline
Old 03-20-2019, 09:37 AM
  #846
Originally Posted by sinisterRC
Hey fellas,
Thanks!!
​​​​​​The disks generate more down force by not letting(as much) air in through the wheels.
Old 03-20-2019, 01:54 PM
  #847
sinisterRC's Avatar
Actually for setting up the car. Some measurements are best done without the swaybar.
Thanks for the answer to the disk question!
Old 04-07-2019, 08:18 PM
  #848
ddd228's Avatar
Trader Rating: 24 (100%+)
Arrow
thx
Good question. It depends on the track surface and how tight the track is. Lots of hair pins?
On carpet ,I like a TON of drag brake. Go deeper into a turn.
On loose dirt,too much drag brake is sometimes just too much!
It's all about your driving style.
ddd228 is offline
Old 04-09-2019, 04:45 PM
  #849
YoDog's Avatar
Trader Rating: 28 (100%+)
This is the MRX6 thread though... so I'm sure he is questioning drag brake for 1/8th nitro on road specifically. I'd like to know as well... ;-)
YoDog is offline
Old 04-09-2019, 04:49 PM
  #850
ddd228's Avatar
I'm in the wrong section. I'll go play in the dirt,now.
ddd228 is offline
Old 04-09-2019, 05:06 PM
  #851
YoDog's Avatar
YoDog is offline
Old 04-10-2019, 09:20 AM
  #852
sinisterRC's Avatar
Hey Fellas,
So I took my car apart after a few practice days and noticed this:
The throttle servo was rubbing on the fuel tank, spaced out the servo and problem fixed. Just wanted to give everyone a heads up!
Old 05-16-2019, 04:05 AM
  #853
1/8 IC Fan's Avatar
I think these may look nice on our chassis as well as on the MBX series they were designed for:
Mugen Adjustable Servo Arms (in 23 & 25 Tooth)
OPTIONAL PARTS
sinisterRC likes this.
Old 05-19-2019, 01:28 AM
  #854
mustangkillaz's Avatar
Anyone after a 2nd hand car?
mustangkillaz is offline
Old 05-21-2019, 07:02 AM
  #855
sinisterRC's Avatar
Hello Fellas,
So I tore my 6 down after the season. Everything was good besides the front belt. But I did notice something that has me worried, should the chassis lay perfectly flat on a flat surface? Reason I ask is because I noticed towards the middle of the chassis there is a slight raise of about 1mm. Basically right where the chassis tapers towards the edges (fuel tank, engine area). I am able to slide a piece of paper under the chassis in that spot. Is that ok? Should it lay perfectly flat? Thanks!!
