LC Racing EMB-1H Official Thread
#2716
Agreed. Those prices are a deal killer. Warren RC is in Michigan, I think. Are they still too expensive to get to Canada?
#2717
http://www.borderbuddy.com
#2719
I am driving my all stock EMB-1 buggy mostly on-road (at the moment) on 3s. It is a lot of fun, but the one small issue I'm having is that under hard acceleration is tends to squirm from side to side. The overall direction is constant (it goes where I point it) but it definitely slides side to side as it gets going.
Any ideas on what might be causing this?
Thanks!
Thanks!
#2720
Thanks!
Thanks!
Sounds like the diffs may be unloading - never run 3s but seems like its overpowering your traction. I put a pretty thick diff-silicone in my diff to slow the action, you might want to consider the same. The diffs are not "sealed" but they held the thicker fluid just fine. I think I have 10k in there right now.
#2722
Thanks!
Thanks!
#2723
#2724
I built my EMB-T with the aluminum bell crank, knuckles and hub carriers. Also got the bearing pressed steering linkage from EAC Engineering on Etsy. Shimmed with .3mm thick shims behind the stub axle pins to minimize CVD slop. I have virtually no slop.
#2726
As mentioned above, shims and a tighter steering link. On one of my more used cars the end piece on the link from the servo arm to the steering linkage, (proper name?) became loose and needed replacing.
#2727
Not really. It's sprung weight (vs unsprung weight like wheels/tires/axles/gears/drive shafts). FWIW, I never built it with the plastic pieces and there are many ways to compensate given the overall weight of the vehicle.
I think it's a much bigger deal on something like 1/28 scale.
#2730
Any recommendations for the best grass tires, or is the stock MT wheel/tire setup the best to get?
I'm seeing a lot of discussion on the bent dog bones, but not much on the dog bones tearing into the couplings. On the rear, I'm seeing a notch into the coupling about the width of the small post in the dog bone. Is there any good recommendation for stopping this? I'd back off the slipper, but already seems a bit loose when taking off from a stop.
