LC Racing EMB-1H Official Thread >
Like Tree595Likes
Old 02-13-2021, 01:07 PM
  #2716
Backyard RC's Avatar
Agreed. Those prices are a deal killer. Warren RC is in Michigan, I think. Are they still too expensive to get to Canada?
Backyard RC is offline
Old 02-13-2021, 03:02 PM
  #2717
An EMB-1H lipo RTR from Riptide would be $260 in Canada, with $90 in additional fees. So it's quite a bit more. It seems that LC is willing to open dealers, so an ambitious Canadian should be able to fill a niche quite easily.
http://www.borderbuddy.com
BelknapCrater is offline
Old 02-14-2021, 07:00 PM
  #2718
slick2500's Avatar
Banggood might be the best bet https://www.banggood.com/search/lc-r...e-0-0_p-1.html
slick2500 is offline
Old 02-14-2021, 08:50 PM
  #2719
Trader Rating: 19 (100%+)
I am driving my all stock EMB-1 buggy mostly on-road (at the moment) on 3s. It is a lot of fun, but the one small issue I'm having is that under hard acceleration is tends to squirm from side to side. The overall direction is constant (it goes where I point it) but it definitely slides side to side as it gets going.
Any ideas on what might be causing this?
Thanks!
smirkracing is offline
Old 02-16-2021, 03:38 AM
  #2720
Originally Posted by Charlieuk
what did you use to scan it? Looks great!
Thats awesome I was looking for wider arms already. Did you finish it yet ? Any Updates also on usable Driveshafts?
Al Schizo is offline
Old 02-16-2021, 08:18 AM
  #2721
sacmiata's Avatar
Trader Rating: 27 (100%+)
Thanks!
Sounds like the diffs may be unloading - never run 3s but seems like its overpowering your traction. I put a pretty thick diff-silicone in my diff to slow the action, you might want to consider the same. The diffs are not "sealed" but they held the thicker fluid just fine. I think I have 10k in there right now.
sacmiata is offline
Old 02-17-2021, 02:39 PM
  #2722
Thanks!
Have you tightened up the steering slop? I was surprised at first by how much slop there is. I was expecting the car to slam into the right lane boarder then slam into the left one but it drives pretty straight. Doing speed runs is where it might show up the most.
Old 02-17-2021, 09:32 PM
  #2723
thanks! Will have a look at the diffs.
Backyard, what are the best ways to remove some slop?
Old 02-18-2021, 06:49 AM
  #2724
I built my EMB-T with the aluminum bell crank, knuckles and hub carriers. Also got the bearing pressed steering linkage from EAC Engineering on Etsy. Shimmed with .3mm thick shims behind the stub axle pins to minimize CVD slop. I have virtually no slop.
Backyard RC and Billyboblett like this.
liquoredonlife is offline
Old 02-18-2021, 07:12 AM
  #2725
Thank you!!
I have the linkage from EAC (not yet installed) but i have been staying away from the aluminum knuckles and hub carriers because I was concerned about weight. Sounds like that has not been an issue for you?
Old 02-18-2021, 11:08 AM
  #2726
As mentioned above, shims and a tighter steering link. On one of my more used cars the end piece on the link from the servo arm to the steering linkage, (proper name?) became loose and needed replacing.
Old 02-18-2021, 02:31 PM
  #2727
Not really. It's sprung weight (vs unsprung weight like wheels/tires/axles/gears/drive shafts). FWIW, I never built it with the plastic pieces and there are many ways to compensate given the overall weight of the vehicle.
I think it's a much bigger deal on something like 1/28 scale.
Old 02-22-2021, 05:06 PM
  #2728
slick2500's Avatar
I had to replace that on my recently too, the original one had lasted over 2 years though.
Old 03-13-2021, 05:06 PM
  #2729
slick2500's Avatar
So I recently purchased the EAC Engineering steering rack for my long wheelbase monster truck and man did it make a big difference in the steering.
Backyard RC likes this.
Old 03-17-2021, 02:30 PM
  #2730
Any recommendations for the best grass tires, or is the stock MT wheel/tire setup the best to get?
I'm seeing a lot of discussion on the bent dog bones, but not much on the dog bones tearing into the couplings. On the rear, I'm seeing a notch into the coupling about the width of the small post in the dog bone. Is there any good recommendation for stopping this? I'd back off the slipper, but already seems a bit loose when taking off from a stop.
bourban is offline
