The One True 13.5 Thread >
Old 12-03-2007, 07:11 PM
  #481
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by syndr0me
What rotor do you have in the LRP? It comes with the bonded rotor, so if you don't have the sintered, you'll want to get it. Also, the LRP's sintered rotor is GINORMOUS! You need to give it way more gear than the Novak 13.5 pro, it's got a much smaller air gap, and therefore more torque. Try a rollout around 47mm to start, and work your way around from there. That should put you in the ball park, though.
I have found that a Novak motor with the 13mm sintered rotor will be geared very similarly to the LRP 13.5/sintered.
I was at around a 48mm rollout and I was ROCKIN'!!
JayBee is offline
Old 12-03-2007, 07:15 PM
  #482
JamesnMeyer's Avatar
Trader Rating: 41 (100%+)
This shit is getting on my nerves now. Remind me to NEVER buy anything from RCmushroom. What a prick
Originally Posted by rcmushroom
Dear futureal!
According AD plan provided as follows !
{ 1:Put the banner online since 10 august 2007 to 10 august 2008.
2: The AD Packages(120x240 banner ,12months/$1200 ) will be on your site. }
Please Update the banner of rc-mushroom on your site,
You can log in ftp and download the new banner
AD Link: http://rc-mushroom.com/index.php?cPath=335
The file size is 35px now
You can do, Why not do?
If you have any question, please let me know!
Thanks for your kind attention.
Best Regards,
Jimmy Chan
Email: [email protected]
Website: www.rc-mushroom.com
20071204
JamesnMeyer is offline
Old 12-03-2007, 07:41 PM
  #483
RussB's Avatar
srsly!
RussB is offline
Old 12-03-2007, 07:47 PM
  #484
PitNamedGordie's Avatar
I second that!
PitNamedGordie is offline
Old 12-03-2007, 09:48 PM
  #485
Brian McGreevy's Avatar
syndr0me or anyone else,
Have you tested the new Trinity Duo 13.5 or 10.5 motors? I've been told they're basically a carbon copy of the Orion motors.
Brian McGreevy is offline
Old 12-03-2007, 10:00 PM
  #486
syndr0me's Avatar
Trader Rating: 32 (100%+)
Brian,
I haven't, but they're very clearly Feigao, just like the Orion motors. It's possible there are minor differences, like what size rotor they decided to use, but I doubt you'll see much difference between them otherwise. It's the same company that makes the motors SpeedPassion is turning out.
I personally found the Orion 13.5 inferior to the Novak and LRP 13.5 in terms of performance, and a few others have said the same. It does look like they're experimenting with new rotors, though, so many they'll get things going.
syndr0me is offline
Old 12-03-2007, 10:15 PM
  #487
Originally Posted by pcar951
Ok, here's another one....Several of our club racers have found that the Novak 13.5 Pro is waaay faster than the LRP 13.5. I've tested the LRP and even stepped up for the sintered rotor and, the LRP is a dog compared to my Novak.
Is it cause the GTB is rejecting the LRP like a bad liver transplant or, have I forgotten to adjust the suck control??
BTW: thanks for the info syndr0me, I'll be gankin my fans out tonight
I have both motors and they are very comparable. The LRP has more bottom end. The Novak has a little more top end and it also has a smoother power band.
ittjv is offline
Old 12-05-2007, 03:16 PM
  #488
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Anyone know if this thing can run a 13.5 motor?
http://www.shopatron.com/product/par...65.26354.0.0.0
Its the Novak Super Sport crawler ESC. Just wonderin how capable it is in regular non-crawling situations...cuz if it is then the price its at becomes much more attractive
The downloadable manual from team novaks website says it will go down to 8.5. Here is the link to the manual...
http://www.teamnovak.com/download/in...rawler_ins.pdf
Syber Serulean is offline
Old 12-05-2007, 07:40 PM
  #489
ILDRVR's Avatar
I got to test out my new GTB 13.5 today. Everytime I turn the esc on the motor spins for a second or two. I always have my radio on first then the esc. Does anyone else have this problem? Can it be fixed?
Thank you, I am new to Novak electronics.
ILDRVR is offline
Old 12-05-2007, 08:09 PM
  #490
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Are you running spectrum?
UN4RACING is offline
Old 12-05-2007, 08:59 PM
  #491
If you have a Spektrum just re-bind it,that will fix your problem.
8up-racing is offline
Old 12-06-2007, 07:29 AM
  #492
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
what radio do you have? With my M11 with spektrum i had to turn on the radio wait a few seconds then turn on the esc, if i turned the esc immediately after turning on the radio the same thing would happen.
Marcos.J is offline
Old 12-06-2007, 07:34 AM
  #493
Kevin K's Avatar
Originally Posted by Marcos.J
because the lrp has more timing than the GTB
What does this mean?
Kevin K is offline
Old 12-06-2007, 08:11 PM
  #494
ILDRVR's Avatar
Thanks I do have a spektrum and I will try rebinding it tomorrow.
ILDRVR is offline
Old 12-06-2007, 08:13 PM
  #495
Super Moderator
Marcos.J's Avatar
it means the lrp with the novak 13.5 is faster than the gtb with the novak 13.5
Marcos.J is offline
