Hot Bodies Cyclone
You da man!!
Congratulations buddy!!!!!!!!!
Speedworld has them but before I got mine I was going to try the Tamiya's or the Schumacher pistons. If you stay with 2 hole pistons drop your oil to 30wt. It's as close a feel that you will get to the 3 hole and 45wt some of the set up's have.
So is the track finished??? If not stop posting and get it done and YES....rcracing is down again
Thanks Clint. I'll have to call down there and see if they'll drop me a set in the mail.
-Korey
-Korey
any part number on that piston i am looking for them also
yeah if its available i found the tamiya ones but they arent exactly cheap i would assume the HB ones are cheaper?
73524 - Machined Shock Piston (1.1mm 3 Holes/4pcs)
There ya go man, Clint was just too lazy to look
-Korey
-Korey
Maybe he was too lazy to look. I'm trying to get my mind ready for this weekend. The jedi mind trick doesn't seem to be working in 08. I gotta try something new I may be switching back to the schwartz!!!!
USE THE SCHWARTZ!!!!!!
Very soft... Do you mean it makes the dampening really soft? Or the material of the piston is really soft?
-Korey
-Korey
