1/12 vehicles that use metric hardware? >
Old 11-03-2015, 08:56 AM
Cain's Avatar
Trader Rating: 294 (100%+)
Default 1/12 vehicles that use metric hardware?
Of the 1/12 pan cars out there now that are competitive, which of those use metric hardware?
Cain is offline
Old 11-03-2015, 09:00 AM
Pretty much all the 1/12th scale cars (with the notable exception of Speedmerchant and CRC) use primarlly metric fasteners. Those two cars (which are both US made) use mostly imperial screws.
vafactor is offline
Old 11-03-2015, 09:03 AM
DirkW's Avatar
You mean metric screws?
Xray, Yokomo, Associated... probably some more. Don't know which ones fit your criteria of being competitive though.
DirkW is offline
Old 11-03-2015, 09:26 AM
Cain's Avatar
thinking crc, xray, etc.
out here last time I ran 1/12 crc was quite popular as I think a few of the people were sponsored by them, but I seem to recall the screws weren't metric. So looking to try this class again and would like a vehicle that is, and preferrably one if at all possible that has a battery retaining system that doesn't only involve strapping tape.
I am open to models that are not the latest spec either, like for example what the crc gen xl is to there current lineup if that makes sense.
Cain is offline
Old 11-03-2015, 09:33 AM
valk's Avatar
Trader Rating: 13 (100%+)
Not sure why the type of fastener matters at all..but most cars use tape aside from crc which has a handy oring to hold the battery.
I'd have to look at lukes xray but pretty sure that was tape as well.
valk is offline
Old 11-03-2015, 10:19 AM
Car Breaker's Avatar
X12 use only matric screws so you don't need any imperial tools at all. But you do need imperial bearing though
Car Breaker is offline
Old 11-03-2015, 10:34 AM
swimbikerun's Avatar
Trader Rating: 108 (99%+)
XRay and Yokomo use all metric screws and Associated uses all metric hardware as well minus the screws for the rear wheels.
swimbikerun is offline
Old 11-03-2015, 10:49 AM
bdmpastx's Avatar
RSD RR12 also uses metric except for the wheel screws. I think Xray is the only one with metric hubs. Although XENON makes some 4-40 threaded screws with 2mm allen heads to remedy that. Mine are on the way.
bdmpastx is offline
Old 11-03-2015, 11:00 AM
Trader Rating: 20 (100%+)
TOP also uses metric for the rear wheel screws.
LloydLoar is offline
Old 11-03-2015, 01:37 PM
Trader Rating: 24 (100%+)
My XRAY X12'16 was built using only metric tools.
fenton06 is offline
Old 11-04-2015, 11:47 AM
Default hiro
Don't have it on the track yet buy my hiro factory in all metric with the exception of the rear hubs those are 440 and it uses a o-ring to hold the battery in place
xps800doo is offline
Old 11-04-2015, 02:41 PM
Serpent S120LTR uses all metric hardware, even the rear wheel screws.
Stealth_RT is offline
Old 11-04-2015, 06:17 PM
patorz31's Avatar
Vbc lightning 12 is metric.
patorz31 is offline
