Team Losi JRXS Type-R
#2971
Super Moderator
Originally Posted by POOKYT
So it looks like you brushless guys are only using a fan on the speedo and not the motor right? The reason I'm asking is that I am wiring up all 3 of my fans so I can plug and unplug them as a set. Plus it looks like you cannot use the outer fans if your running the brushless set-up.
Brant
Brant
#2972
Brant
Brant
#2973
Brant
Brant
The solder tabs need to be rotated to the back of the car.
With the Arizona heat here I tried running the outer fans and it did help but I have decided to put the stator sleave heatsink on.
#2974
Originally Posted by kyle478
With the Arizona heat here I tried running the outer fans and it did help but I have decided to put the stator sleave heatsink.
#2975
Originally Posted by syndr0me
That should make outdoor racing in August around here exciting. Have you been able to use the stator heatsink in the Type-R? From what I can tell, you'll have to remove the bulkhead to insert the motor if it's got that heatsink on it.
Yes i ran the heatsink and it makes a huge difference. I think there are 6 screw you have to remove to get the bulk head out.
#2976
Brant
Brant
You CAN use the outer fans for brushless; take a look at the photo (just visible) of my wiring job to prove it.
#2977
Brant
#2978
Duckman--Thanks for the pic! Looks good the way you have it laid out.
BTW---did you seperate the red/blk/white speedo wires and then run them in the fins on the GTZ heat sink? From the pics that is what it looks like. If so then that is awesome!!!!
Brant
Brant
#2979
Hi all,
Well, I now have my car wired up and setup ready for a bit of tarmac running, hopefully on monday. Have the car setup as the kit asphalt setup (Spool, F; 15lb, 0.4" bar, low rc, R;10lb, 0.3" bar, low rc), anyone got any other tips/tricks to help on it's way?
One thing I have noticed, I've had to reduce the EPA on my steering servo down to 60% L&R to stop the horn hitting the top deck. Now I assume that because of the short amount of servo throw required to get full lock, that the steering might feel quite twitchy... how much curve/expo do people run on there steering with the car?
Bear in mind, I'm coming from a tamiya where full lock takes about 90-95% of the servo throw, and with that I tend to run around -15-20% curve.
Cheers
Ed
Cheers
Ed
#2980
Originally Posted by duckman996
Yeah - I did run the wires through the heatsink... I actually used a new lead from the receiver, routed it around the servo and then soldered it onto to GTX prongs. I was tired of worrying if the plug would come undone in a race. I also wired a new switch and soldered those leads on as well... It makes for a really clean finish on the wiring and eliminates the worry that the plug will come undone from the speedo (since its mounted sideways, that increases the chances).
#2981
Yo Super J!!! I only see a fan on your speedo. maybe I'm missing the others but we were talking about the fans for the motor.
Brant
Brant
#2982
I'm building the typr r. I see the front and rear suspension has so much slop. Where can I buy the shims and in what size thanks
#2983
Pook- You are right, but I was trying to illustrate the point that if you solder your motor leads to the brushless endbell the way I have in the photo, you CAN put fans on the 'endbell'.
lol I figured that out after one of the other guys posted his pics too. HEHE
Brant
#2984
Over all the years I have driven Losi vehicles, the play in the arms and such really used to drive me nuts. I spent hours shimming this or that and after many years of I finally came to the realization that either I didn't drive well enough to know the "play" was in or out of the suspension. I gave up on it unless it was really in excess. Usually if it was in excess then I needed to replace some worn parts. I guess what I mean by all of this is that you probably need to drive the carfirst then shim stuff out to see if you can tell the difference. Hope this helps.
Not to mention that after I spent time to shim things perfectly, it seemed than within the next two battery packs I would break an arm or something and the shims went flying!! Total frustration and I just said no! LMAO
Brant
#2985
HiH
Ed
