Schumacher Corner
#1307
I've just got my Titanium CVD's, very light is something of an understatement. They weigh about the same or a little less than the kit plastic items.
I know it's not a very good quality pic, but should give some idea.
#1308
Can someone please give me a link to a schumacher mission setup sheet so I can make one for Ron? I can't for the life of me find it on the racing-cars site. My email is [email protected]
#1309
Adrian or PW,
When are we going to see the setup that PW used for MOD Sedan on foams? My LHS still cant get through to put in my order for my Mission and hop-ups.
IKE
IKE
#1313
Snowbirds setup for Foam tires:
Front:
Tower/1
oil/80wt
piston/2 hole stock
spring/35 lb
suspension mount/1
hubs/inline
swaybar/thick (#u2245)
castor/1 thin kwik clip in back
arm mount/1
arm sweep/2 deg
ride height/5mm
tires/Jaco plaid
Rear:
tower/1
oil/80wt
piston/2 hole stock
spring/35 lb
suspension mount/1
hubs/inline
swaybar/stock
inboard toe/2 deg
arm mount/1
ride height/5mm
tires/Jaco purple
PW
Front:
Tower/1
oil/80wt
piston/2 hole stock
spring/35 lb
suspension mount/1
hubs/inline
arm mount/1
arm sweep/2 deg
ride height/5mm
tires/Jaco plaid
Rear:
tower/1
oil/80wt
piston/2 hole stock
spring/35 lb
suspension mount/1
hubs/inline
swaybar/stock
inboard toe/2 deg
arm mount/1
ride height/5mm
tires/Jaco purple
PW
#1314
What extras do I need for the Mission. Any hop up's needed ??
#1315
Congrats to all the Schumacher drivers at the Snowbirds, especially in 19T and to Ron Atomic.
TractionRoll: Everything you need really comes with the car. You may need some springs (red and yellow), threaded shock bodies (if you don't like the spacer thingies), and a one way (if they are the hot ticket at the local track). Other than that, you will need to keep coming here and make space for all the trophies (lol).
#1316
Got my carbon Mission today...have to wait till friday though before I start. I got some hopups coming that I want to build into the kit. Looks good!
BTW, did anyones tires, foam, bumper and wheels come 'loose' in the box? Its all there...but just wondering.
Sean
Sean
#1317
PW,
what was your starting diameter with the tires?
IKE
IKE
#1318
-Sean
#1319
Where is the upper deck from? I mean the one that can be seen on Ron's car.
