Best Front Downforce Body? >
Old 07-11-2005, 08:41 AM
Trader Rating: 14 (89%+)
Default Best Front Downforce Body?
Was wondering what body was going to be the best for providing my car with more front grip? I currently run the Dodge Stratus 2.0 and also have a Alfa but haven't run that one. Thanks in advance.
dmayhew25 is offline
Old 07-11-2005, 10:20 AM
polesitter61's Avatar
I love my RIDE MKII, it seems to give me the most steering of any body I have, even the Mazda 6.
polesitter61 is offline
Old 07-11-2005, 11:35 AM
Soviet's Avatar
The body that reduces your front spring rate
or
The body that reduces your front oil's viscosity
or
The body that increases positive caster on your front wheels
or, last but not least
The body that puts your front wheels at -1.5 camber and your rears at -1.0.
Sorry, but I was lurking.....
Soviet is offline
Old 07-11-2005, 11:43 AM
AdrianM's Avatar
Yup, Ride MKII then the Mazda 6 and Status 3.0AP.
AdrianM is offline
stormperson's Avatar
The AP stratus 3.0 has alot of front grip, however on anything from meduim bite carpet and above traction wise I would be weary of using it since it screws the front end of the car into the ground, robbing corner speed and boggin down the car. The mazda 6 has alot of front end grip, however i have always found it to be really twichy and then as soon as it starts to turn, push really bad from the center to exit of the corner.
For meduim to high bite carpet the parma alfa is the body you want, with alot of very smooth easy to drive steering.
stormperson is offline
Old 07-11-2005, 11:53 AM
AdrianM's Avatar
I think dmayhew25 is running on asphalt. It doesn't sound like a carpet question unless he runs rubber tires.
Like you said the Parma Alfa is the only body to run with foam tires. With rubber tires on Asphalt or Carpet the Ride, 6, 3.0AP would be better.
AdrianM is offline
Old 07-11-2005, 12:02 PM
Matteucci's Avatar
Adrian, Who makes the "Ride" body?
Matteucci is offline
Old 07-11-2005, 12:05 PM
raving-monkey's Avatar
hmm...Ride
i think Speedtech stock them...i've been trying to get hold of a accord for ages but cna't find anyone in the UK that stocks them...i guess i will have to get one when i order from speedtech (soon hopefully )
raving-monkey is offline
Old 07-11-2005, 12:09 PM
Trader Rating: 18 (100%+)
Best downforce body? hmm I think its the cadi
Roberto Falcon is offline
Old 07-11-2005, 12:13 PM
or
or
Great answer! I agree 100%
Rody is offline
Old 07-11-2005, 12:29 PM
edseb's Avatar
If you're are just looking for front downforce, I'd look at the Yokomo Stratus Type E. It's twitchy as hell and not as stable as Protoform Stratus 3.0AP or Mazda 6, but if you need more steering...
edseb is offline
Old 07-11-2005, 12:35 PM
axel's Avatar
i raced a mazda 6 for most my racing time...and i just switched to the stratus 3.0 and i love it ...it's really stable. The mazda 6 is also a favorite of mine. The mazda 6 doesn't really need explanation at this point it's already well known to work well on ashplat.
axel is offline
Old 07-11-2005, 01:30 PM
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Randy Caster is offline
Old 07-11-2005, 01:42 PM
fatbear's Avatar
Which body shell would you guys use for foam tires on ashfelt? Stick with the Parma Alfa or go to one of the good rubber tire body shells. I must point out this is foams on ashfelt with absolutely no additive allowed.
fatbear is offline
