Ask Paul Lemieux, RC America/MOTIV/Gravity RC >
Old 03-28-2013, 06:46 AM
  #2131
Gravity RC
Originally Posted by Mera'din
So, don't change the rear fluid? That is why i was asking about. Didn't think of going harder in the front.
I would leave the rear for now, i would first try thicker in the front. if the traction is med to high grip then going to 2k cst in the rear could help but i kinda think your problem is more likely to be in the front diff.
Originally Posted by R1wurks
Paul. I think your PMs are full, my PMs not going thru. Can you pm me when you get a chance. Thanks!
Sorry, fixed.
Paul L is offline
Old 03-28-2013, 12:31 PM
  #2132
TAMAK's Avatar
Trader Rating: 29 (100%+)
Hey Paul,
What servos do you use on your NT1? Thanks
TAMAK is offline
Old 03-29-2013, 08:09 AM
  #2133
Gravity RC
Originally Posted by TAMAK
Hey Paul,
Hi. for the throttle i normally use the Futaba S9351, for the steering i normally use the short case S9551.
Paul L is offline
Old 03-29-2013, 07:42 PM
  #2134
LasagnaCat's Avatar
Trader Rating: 161 (100%+)
Originally Posted by Xpress
What's the best way to remove dirt from the heads of screws on the bottom of a 4wd buggy?
Dental pick
LasagnaCat is offline
Old 03-30-2013, 07:57 AM
  #2135
Paul - what motor setup did you run at the worlds (or the warmup) last year? Rotor / gearing etc etc.
cheers Matt
MattW is offline
Old 03-30-2013, 08:28 AM
  #2136
Xpress's Avatar
Hey Paul, any news on the Gravity Ti screws?
Xpress is offline
Old 04-01-2013, 10:02 AM
  #2137
Gravity RC
cheers Matt
Hi Matt. I used a 4.5T with the included purple rotor, 20deg timing, 8.1 gearing. 20deg boost timing and 20deg turbo timing. Thanks
I have some Kits and screws availible. At first I will be selling only the screws direct at a discounted price. [email protected]
Paul L is offline
Old 04-01-2013, 01:40 PM
  #2138
Cheers Paul, is that with HW speedo??
Been trying TP 4.5 on and off for the last few test days i've done, and so far, a bit too much heat, not quote as much power as what I've used before - more work required. Need to try a different speedo.
MattW is offline
Old 04-04-2013, 05:46 PM
  #2139
B00t13g's Avatar
How do you personally detweak your chassis?
B00t13g is offline
Old 04-05-2013, 08:57 AM
  #2140
Gravity RC
At the worlds i did use a hobbywing speedo and that is the general set up that i used. i would apply those timing settings to any speedo to start though. as for the heat make sure that your motor timing is no lower than 15deg and no higher than 20deg, this is where the motor will run its coolest. also if you were trying any optional rotors i would revert to the stock one with these settings. Thanks
First i make sure that I have all electronics and weight in the car (race ready but with no tires) then i put the chassis on droop blocks, i will then turn the blocks by reaching my pinkie fingers under the chassis, as the blocks turns you will be able to feel its pivot point which will tell you where and how severe the tweak is. If adjustment is necessary i will then loosen all the top deck screws one by one and just snug them (only tight enough to hold its tweak), then i will put the car back on the blocks and lightly twist it by hand until the blocks will turn with iether no recognizable pivot point or it pivots directly in the center which means you are getting absolute Even pressure from the chassis all the way across the droop block.
Then i tighten each screw one by one going over the top deck two or three times. and you should be good. This is the only way that i have found to get the chassis tweak absolutely perfect, and its not that hard once you get the feel for it.
Paul L is offline
Old 04-05-2013, 10:28 AM
  #2141
B00t13g's Avatar
That makes sense, ill give that a shot! Have you found the lower chassis screws to hold any real tweak, or are you able to just tighten them up and go for lack of a better word? Thank you for all your help!
B00t13g is offline
Old 04-05-2013, 11:00 AM
  #2142
Cheers Paul.
It's unlikely that I'll try a HW speedo for a variety of reasons, but will probably try LRP at some point.
MattW is offline
Old 04-05-2013, 11:42 AM
  #2143
Gravity RC
[QUOTE=B00t13g;12013006]That makes sense, ill give that a shot! Have you found the lower chassis screws to hold any real tweak, or are you able to just tighten them up and go for lack of a better word? Thank you for all your help![/QUOTe
Yup. I will only loosen the lower screws if it is tweaked more than normal.
Cheers Paul.
yup, Im running the flow in my car right now and really liking it, i am just am yet to run it on a really big track
Paul L is offline
Old 04-05-2013, 12:28 PM
  #2144
defcone's Avatar
Trader Rating: 15 (100%+)
[QUOTE=Paul L;12013251]
With thunderpower motors?
defcone is offline
Old 04-05-2013, 01:10 PM
  #2145
B00t13g's Avatar
Thanks Paul, much appreciated!
B00t13g is offline
