Kyosho VoneR Thread
#3226
Originally posted by dtm
What? you mean like if you want a crap car you buy a Pro 3.......and if you want a crap expensive car you buy a Hara edition????? Thats cool!!!! I hope other manufacturers DON'T catch on to this...............
#3227
That is HARSH
#3228
Originally posted by HEYALIGNMENTGUY
That is HARSH
That is HARSH
#3229
I do understand that the stock HPI kits are ok, but when you want to make it competitive you got to stick tons of HOP-UPs just to make it decent, Thus my Super Nitro still sits on a bench with about 1,000 in hop ups
#3230
#3231
Wise choice...stick with the V1!
#3232
Clutch adjustment...
Hi,
I'm running the stock clutch on my V-1-R. I run my car on a small track and i cant make the gear to shift to 2nd gear the earlier the possible. I have loosen the clutch (spurs gear) to about 4.5-5 turns out from tighten, but the gear shift is late...the gear shifting timing seems the same when i loosen the 2 screws from 4 turns to 4.5 turns...should i loosen some more?
what is the range for setting these screws? (how many turns)
What's wrong here? Am i setting the clutch correctly?
When i try throttling the car off-ground, the gear shift is early and fast, but when run it on track, the gear shift timing is still slow and only kick in when i about to corner at the short straight. If i really want the gear to shift, i had to punch the throttle like crazy right from the short straight but almost lost control of the car...
Hope u guys can help me out...
Thanks...
Thanks...
#3233
Re: Clutch adjustment...
Originally posted by RClover
Hi,
Thanks...
Hi,
Thanks...
To make your 2 speed adjust earlier (YES) you have to lossen the screws, Just keep doing this in small incriments, untill you get the desired effect
#3234
Hi,
Thanks...
Hi,
Thanks...
#3235
Re: Re: Clutch adjustment...
Originally posted by Manticore
the problem is with the engine clutch but not the 2speed clutch. the stock clutch is too soft and the car wouldnt have enough punch to let the 2speed engage.
#3236
LIGHTENED FLYWHEEL
Lightened Flywheel Question
hi guys .. ive got a few questions for the techies out there ..
- does a lighter flywheel gives more acceleration ?
- does a lighter flywheel decrease topend speed ?
- to anyone who uses a low cg flywheel - how many grams does
the flywheel weigh ??
ive got an rb x12t on a v1rr and it gives a lot of punch but would like to use a 18 22 pinion on it but dont want to loose too much
of the punch .. i was thinking of lightening my flywheel to
compensate for the loss by using such a gear ratio .. any
comment suggestions or violent reactions would be appreciated
TIA
TIA
#3237
Re: Re: Re: Clutch adjustment...
Another thing could be a rich low end on the engine...this kills the initial torque really badly..often enough not to have the 2nd speed. I hope you are adjusting BOTH screws by the same amount? and there is no grease on the clutch (both engine and 2 speed?).........You could also try a smaller pininion 1st gear....or larger spur gear....just a few options up your sleeve.
Thanks for u guys' response...appreciate that. Just dismantled the spur gears and clutch for inspection. Discovered that the inner metal housing of 2nd spur gear (44T) had 3 - 4 deep cratches causing the metal surface uneven. This, i guess is the problem as the 2-speed clutch may have lost its efficiency due to the uneveness of contact patch between the 2nd spur gear metal housing and the clutch.
I recalled when i first break-in my RBX12 engine, i could have over-tighten the 2 clutch screws (to prevent it from engaging to 2nd gear) and causing the screws protruding out from the clutch and touched the 2nd spur gear metal housing, leaving deep scratches on it...
Have it replaced and gonna try tomorrow if it shift the way i want it...
cheers mates...
#3238
Re: Re: Re: Re: Clutch adjustment...
Hi everybody,
cheers mates...
Hi everybody,
cheers mates...
#3239
Belts
I have a question for any V1R or RR owner. My question is, are the belts that kyosho uses for the two cars kevlar belts? Do they last for a while? I have a Reflex and I want a better belt, I was told that the kyosho is better.
My second question is does anyone have part numbers and prices for the 3 stock belts. Thanks.
#3240
Re: Belts
Kevlar belt in R are stronger and more lasting but will not be as smooth as the SP belts in RR.
The Sp belts in RR are softer (elastic), thus providing the smoothness drivetrain throughout especially so when running alu pullies or stock RR graphite pullies...
One thing though, the RR middle belt is shorter at 375 whereas the R is longer like 378 or something...as the RR middle side pulley is an overdrive at 25T which is designed to be used in conjunction with the 375 SP belts...
Not sure if these belts fit your Reflex...u gotta try it...
