Corally SP12X
#526
Front silver
Rear gold
This combo always has grip.
If it is a high traction track try silver rear as well.
#527
Hey guys, I decided to sell my Corally SP12x WC car. Here is the link to the F/S thread
http://www.rctech.net/forum/r-c-item...2x-wc-kit.html
#528
Hey guy's I have a gearing question Im racing on a 50 X 25 carpet track with a 1.75 rear tire how should i gear a 17.5
#530
#531
I know that Corally have tires on 38 US wheels.
Here are the compound they have.
I'd like to know the equivalent with Jaco or Parma or CRC tires
FRONT
Lilac
Magenta
Purple
Double Pink
REAR:
Magenta
Orange
Gold
Grey
Pink
Double pink
Thanks in advance
FRONT
Lilac
Magenta
Purple
Double Pink
REAR:
Magenta
Orange
Gold
Grey
Pink
Double pink
Thanks in advance
#532
Noline,
At Vegas, I ran a 74 Spur with a 53 pinion with the Speedpassion motor. The track was much arger than what your describing, so I would recommend using a 50/51 pinion if your going with the Speedpassion.
For the Novak/Hacker motors, I would start with a 40/80 combo and go from there.
Good Luck!
Good Luck!
#533
Hello,
I've a Corally 12X WC and Jaco prism tyres...my problem is that the wheel touch the spur.
With old style wheels (no offset) it's ok but prism wheels have a 3mm offset...can you tell me how i can do to fit the Prism wheels on my car.
Thanks in advance
Thanks in advance
#534
We ran into this and fixed it by running a file on the inside edge of the rear wheel while spinning it on the tire truer. Only needed to take about 1/2 mm off, if that. It was mostly interference from the foam overhanging the wheel, not the wheel itself.
#535
Thanks for the help. I'll do that.
Do you have a good basic setup for carpet???
Hugo
#536
These are the changes from Jeff's Snowbirds setup on page 14 of this thread:
Center shock: Silver spring and 30 wt. Assoc. silicone shock oil. (there were no bumps on this track. If this setup is too aggressive or doesn't handle bumps for you, go back to the olive (green) spring, 25 wt. oil, or both)
Dampner Lube: Corally blue. Same comment as center shock, go back to red if necessary.
Tires: No change, except 1.64 fronts and 1.74 rears. We tried 2pink front and rear, 2pink fronts with yellow rear, and lilac fronts/yellow rear. Lilac front/yellow rear was the best (all Jaco tires).
The bite was about medium, so I know these changes will be good with high bite. We'll try even more aggressive settings next time we race on high bite.
#540
Corally SP12X new user.Help needed
Just purchased a Corally SP12X with Associated front end.
It is built as per kit,front springs weight ??????. Fitted the RS front blocks so smaller tyres can be used.
Every thing else is as per kit, tpiece thick ,Any adjustments mods i should be doing.Set ups etc
Plan to run brushless,10.5 on carpet.
Any help appreciated
