Serpent 710
#9046
Radio
Hey guys i am thinking of getting a new 3PK but i dont know which one do i want 40mhz HR or PCM whats the difference?
#9047
Re: Congratulations
Originally posted by Voodo_Magic
You should all give yourselves a pat on the back!
Ummm, does this mean that the new kits will have this FAQ printed is glossy paper?
#9048
Re: Radio
If you plan to use HRS receiver, then make sure ALL your servos are digital. PCM receiver gives you the flexibility of allowing you to run analog servos as well as digital servos.
Other than that, everything else is the same !
#9049
Re: Re: Congratulations
Originally posted by InitialD
Ouch ouch ouch !
Ouch ouch ouch !
#9050
Re: Re: Re: Congratulations
Originally posted by markp27
I'd have to buy a new kit - I've heard a lot of good things about this FAQ
#9051
#9052
Re: Re: Radio
Apparently, HRS is faster than PCM. Whether you feel it or not is another question !
#9053
Re: Re: Re: Radio
I am using an OLD M8 at the moment which is desperately ineed of an upgrade do you guys recommend this radio?
#9054
Re: Re: Re: Radio
I am using an OLD M8 at the moment which is despratly ineed of an upgrade do you guys recommend this radio?
If you wanted to upgrade something, I suggest getting better servos.
#9055
Re: Re: Re: Re: Radio
What do you mean old M8? It's still one of the better radios out there. The top old dawgs arte still using them. Only lacking is a fail safe which you can get one externally.
#9056
Re: Re: Re: Re: Re: Radio
Its old and keeps turning itself off for somereason and there are no airtronic dealers around so by the time i have sent it overseas to get repaired i probably could have bought a new one and i would look at the new M8 but i thought this (3PK) might be better?
Anyway, if the M8 is really toast, you may want to consider the KO Helios. I hear somebody got it and is singing praises ! Smallest receiver I've come across. The features are cool too. But the only downside is no built in fail safe.
#9057
Re: Re: Re: Re: Re: Re: Radio
I thought I heard that problem before and it was a very simple solution. Can't remember what it is. Perhaps somebody else can give some input on this...
Thanks for the advise "D"
#9058
Serpent 710 FAQ
Hi all ~
I think the most important thing in the FAQ is in the last 2 pages ~ haha
my question is ... on page 25 , about engine ... what's WOT stand for ?
thanks ~
thanks ~
#9059
Re: Serpent 710 FAQ
#9060
Re: Re: Serpent 710 FAQ
Wide Open Throttle
Wide Open Throttle
