TLR TEN-SCTE 2.0 Kit Thread
#1396
I'm getting ready to go pick up my kit at my LHS when they open and was wondering if I'll be set assembling it w/ this hex driver set? http://www.amainhobbies.com/product_...FShgMgod0CwA7g
#1397
Tech Prophet
Noticed during my build-
- The front arms contact the chassis droop inserts - even with the droop screws backed all the way out. Not sure if this will limit maximum droop once the shocks are on. Also the screws will eventually dig into the plastic of the arms as they contact over and over.
- the manual says to set the sway bars flush with the balls. If you do so not only does this pull the sway bar in the front very tight - it also impacts the rod ends under compression when using the lower outer camber link holes.
Swaybars. Flush is a good starting point but I always adjust mine to make sure the bar is not binding the suspension which you have to test without the shocks on the car. Check this front and back. Also the small set screws that take the slop out of the swaybars on the bulkhead make sure those are not tight. They are just to take out play and not restrict the movement of the swaybars.
#1398
So we run an extra .6mm on the rear and 1.2mm on the front.
#1399
These were just some thoughts on my build that I PM'd to a friend. Some of these might have been mentioned before, but some might not:
- use the little packet of brown grease on the outdrives when you build the diffs - the manual calls for black grease but use the brown stuff
- pre thread the diff screws before building your diffs as the holes are pretty tight
- the front camber rod ends will impact the sway bar "ball" end when using the lower outside camber holes - you'll need to adjust the position of the sway bar ball to clearance it
- you can't screw in the front triangle bulkhead piece after installing the body mounts so leave the body mount off when installing the front clip and install it after
- same with the front torque rod - attach it to the bulkhead brace before screwing the brace to the steering posts
- build the center drive shafts and attach to pinion before closing up the transmission case so you can eliminate play between the pinion and the Ring gears
- lock Tite the aluminum motor mount to chassis screws - not indicated in manual
#1400
#1401
ok, so of course i have one of the first kits and the bottom caps for the shocks are tight as explained and dont like it....do i call HH to get something done about this or whats the current status on this? Never had a lower cap for the shock thread this hard and i even had pliers with and without a rag so i didnt ruin them and they only go on about 1/2 way
#1402
Seems like there's going to be a lot of trouble building my first kit, not very happy about that but what can you do, I just remembered I need to pick up a pinion gear, mod1 right and what's a good one to get for my 2.0 tekin pro4 4600kv setup on 2s lipo
#1403
If you grab the lower cap after it is threaded on by hand as far as you can get it on the lip that the shock boot normally goes over and hold straight, you can use a shock cap and the top cap tool and slowly thread the bottom cap up all the way. this is all explained in the build tips.
#1404
People are giving tips that they have figured might help others. There is only one minor issue and that is the bottom caps which yuo can get on with a little effort. The build is great from what I have been told by most.
#1405
I think I saw a pic a few pages back w/KHeadz motor/diff mounts on a 2.0. Obviously 2.0 has the same mounts as the 1.0? You guys think these are a good upgrade?
#1406
I understand it just seems like there's so much but maybe I'm over thinking it, well I'm about to leave hopefully my LHS has some mod 1 pinions, what's a good range I was thinking maybe 15-18
#1407
That depends on your motor, most are in the range of 12-15 I would say.
#1408
I'll be running the pro 4 4600kv but alright thanks I'll probably pick up 2or3 pinions
#1409
Also, Anyone have an inside on pro4HD's release? I'm undecided on a motor for this truck. I've been running the 4000pro4 in a Rango and like it for indoor but the 2.0 being a little heavier, I think I want more power but would like to keep it smooth. pro4 4600, HW4700 4XS 4800 or 7200, SC411? Bad words for any of these?
