F201
Old 06-04-2004, 12:20 PM
  #1471
psycho's Avatar
Neil
Look for a movie called "Faster" It should be showing somewhere in your area.
psycho is offline
Old 06-04-2004, 01:20 PM
  #1472
losispeed's Avatar
Originally posted by Neil Rabara
Who will make it out to the TCS regional at Tamiya HQ?
When is it going down?
losispeed is offline
Old 06-04-2004, 02:57 PM
  #1473
Neil Rabara's Avatar
Originally posted by psycho
Neil
I haven't heard of that movie at all. Is it a lower budget movie?
Neil Rabara is offline
Old 06-04-2004, 03:47 PM
  #1474
psycho's Avatar
http://www.fastermovie.com/ Watch the trailer. Good stuff! It's from the 2002 MotoGP season, so why Rossi, Biaggi and Capirossi are not in their current livery.
psycho is offline
Old 06-04-2004, 05:16 PM
  #1475
It's looks cool. They run 500cc? This is a different class than the 600's and Liter's?
Old 06-04-2004, 05:50 PM
  #1476
psycho's Avatar
In the past, the premier class was 500cc 2 strokes. In 2002, they allowed 500cc 2 strokes and up to 990cc 4 strokes. As of last year, the 2 strokes were outlawed in the premier class. Since this movie covers the 2002 MotoGP season, some guys are still on 2 strokes. MotoGP doesn't race road bikes. They are all "race bikes." You have 125cc, 250cc (both 2 stroke) and 990cc 4 stroke in the premier class. World SBK series races road bikes. Superbike are all literbikes. Supersport are all 600's with a couple 750 twins mixed in. The Supersport class is the more exciting of the two, imo.
psycho is offline
Old 06-05-2004, 08:15 AM
  #1477
I'm starting to watch more and more the AMA Superbike series. Not so much the supersport.
Old 06-05-2004, 08:34 PM
  #1478
psycho's Avatar
I haven't kept up with the AMA in th elast couple years. Since I only have a 120GB disk in my Tivo, I had to cancel some of my season passes! I only watch ALMS, F1, MotoGP, WSBK,, CART and WRC. Woohoo! 24 Heures du Mans next weekend! I'll be watching every minute of it! MotoGP tomorrow too.
psycho is offline
Old 06-05-2004, 09:36 PM
  #1479
June 27.
Old 06-08-2004, 02:07 PM
  #1480
mtveten's Avatar
Trader Rating: 29 (100%+)
Has anyone experimented with cutting holes in the body to improve airflow around the motor, if so did it help?
Also where could I cut the holes and still be TCS legal?
Are the use of cooling fans and clip on heatsinks permmited by TCS rules?
Thanks,
Mark
mtveten is offline
Old 06-08-2004, 04:14 PM
  #1481
Cutting holes in the body is not TCS legal. The use of fans and heatsinks isn't specified in the rules, so some people use them.
Old 06-08-2004, 04:23 PM
  #1482
mtveten's Avatar
Oh well I guess I will just have to stick with my heatsink and fan.
mtveten is offline
Old 06-08-2004, 06:05 PM
  #1483
jackhammer74's Avatar
Actually for '04 Tamiya is allowing the F201's chassis to be drilled for cooling purposes, but the rule is a little vague, it states "Cutting of the chassis for weight savings is not allowed. However, due to the high heat generated in the motor area, holes may be drilled for heat dissipation around the plastic that encases the motor. Holes may also be drilled to access the tight confines of the electronics wiring. "
I for one would like to get some clarification as to what entails "the plastic that encases the motor".
jackhammer74 is offline
Old 06-08-2004, 09:25 PM
  #1484
The plastic directly below the motor on the main chassis bottom. You can cut holes in the upper chassis next to the motor for better access of wiring to the motor.
Old 06-08-2004, 09:54 PM
  #1485
Turbonium's Avatar
Trader Rating: 27 (100%+)
thats just what i did... hopedit would be ok. oh yeah... what would you guys use as far as springs on asphalt? Juns setup called for olive (firm) front,a dn black(soft) rear... sound ok?
Turbonium is offline
