3racing F109
#991
Hello guys!!
This is my first post to this forum and there is not a better way
to start this, but to post some pics
Special thanks to INZANE !!! your post's have been a really big help!!
#992
LOVE THE PAINT SCHEME!!
Different from the usual team livery but yet looks like it could be an actual real F1 team.
Is that a F104 Pro body?
#993
Which wheels and tires do you have on that?
#994
Most parts are interchangeable between the F1-09 and Tamiya F103/F104 - except for the chassis and motor pod of course (F1-09 is a link car, Tamiya a T-bar car).
The obvious question is why you'd want to use Tamiya hop up parts
The are pricey without being any better - IMHO.
The only Tamiya parts I use are the 3.5 mm offset knuckles, center shock spring (Touring spring set) and the thrust bearing in the 3Racing Out Tuned diff. I'm thinking about using the F104 rear carbon axel as well - but that's about it.
As for other hop up parts I use the alu caster plate, servo horn, Out tuned diff (nearly a must have for ALL F1 cars) from 3Racing, the CRC mod (CRC spring holder and CRC or AE side springs), Zen king pin (longer than kit pins so I can get height adjustment) and front springs from AE.
I'm thinking about getting the F109 kit..Do you recommend hop up chassis instead of stock one?
Why the alum caster plate? What is your wheel width of your F1? Thanks
#995
FREAKAH:
Thanks!! Body is stock F109 body.
Paint scheme is my own.
InspGadgt:
Ride medium tires and Ride rims.
InspGadgt:
#996
gear setup for 540 motor
#997
Are you asking for pinion/spur setup?
If so..
You need to do roll out to get the gearing "right" for a 540.
Tire diameter plays into this.
Head over to gearchart (with a .com)
and plug in your info using the pan car option.
With cooling we (guys I race with) are running 47 to 56mm (some push more depending on track layout) .
Indoor carpet we were at the lower side of that number.
Without a fan or heat sink stay low,run a few laps and pull in to check temps.
The new 540j will unglue the magnets or push back the com. when they get too hot and you jar them so be careful .
If so..
#998
#1000
If you are running 540j motors the diff is a bit of a hassle finding pinions that will work.
It's been said before but I wanted to post it up again.
Found this problem to be alot more annoying at the track than I thought it would be when I ordered the diff.
#1001
The plastic caster plate is prone to break and you can tighten the alu one a lot harder.
OK - some explanatory pics of the changes made for Boras GP;
Increased droop
Inserted a rebound spring inside the center shock
Unscrewed the ball end about 2mm
Taller rear shock post
Setup sheet>>
Todays bonus pic - inside scoop on the CRC mod
#1003
thanks for your reply. Didn't look at the F104 section, so I couldn't found it. Looks like the 3Racing version of the F104 diff. Does it work with the kit rear axle?
Because if I remember correctly the F104 has a different rear axle than a F103 respectively F1-09.
orci77
#1005
F1 & 24 Minutes Le Mans at TQ Sat 5/6/2010
From this weekend, we will have Sunday Club Race.
We have UF1 Series on June 5th, Saturday.
11:00 doors open
1:30 sign ups end
2:00 first 10 minute qualifier (no more than 10 drivers per qual)
2:20 second qualifier
3:00 first 8 minute round (B group)
3:20 second 8 minute round (A group)
3:45 third 8 minute round (B group)
4:05 fourth 8 minute round (A group)
4:30 fifth 8 minute round (B group)
4:50 sixth 8 minute round (A group)
11:00 doors open
1:30 sign ups end
I installed 21.5 in the "C" group hoping the battery will get me to the finish line.
This will be the our 2nd Le Mans run, bring your cars
Cheers!
Marcos
