New Yokomo TC, the BD-5 >
Old 06-15-2009, 01:18 AM
  #601
Default holgura
Hello and noticed that the steering system of the bell crank and link the center there is much slack, someone corrected this, how fix?
manchu is offline
Old 06-15-2009, 01:20 AM
  #602
kschu's Avatar
Trader Rating: 16 (100%+)
do you mean the freeplay ??? i put 0.5mm shim on both side...
kschu is offline
Old 06-15-2009, 03:24 AM
  #603
Default shim 0,5
How could you indicate where it shim 0.5
manchu is offline
Old 06-15-2009, 05:15 PM
  #604
kschu's Avatar
i just add the shim till it's has minimum free play....i add o.1mm at 1 time ...so both side end up added 0.5mm...
kschu is offline
Old 06-15-2009, 05:54 PM
  #605
JimmyMac's Avatar
Anyone know the spring rates for the white series Yokomo springs (like the ones on the car)?
JimmyMac is offline
Old 06-15-2009, 06:26 PM
  #606
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
For Yokomo Progressive springs(white springs with color code dot)
YS-1460L Black 14.50 Softest
YS-14575L Blue 14.80
YS-1455L Yellow 15.70
YS-1565L Pink 16.26
YS-15625L Green 17.00
YS-1560 Orange 18.50 Hardest
Shopkeeper is offline
Old 06-16-2009, 12:13 AM
  #607
JimmyMac's Avatar
YS-1565L Pink 16.26
Thank You very much!
JimmyMac is offline
Old 06-16-2009, 01:28 AM
  #608
niznai's Avatar
Does anyone know the part number for the suspension arms for BD5?
Are they different front to rear? I need to assess if they would fit the SD-SSG.
niznai is offline
Old 06-16-2009, 02:16 AM
  #609
kschu's Avatar
front arm - bd008F
rear arm - bd008R
they both are different...
kschu is offline
Old 06-16-2009, 03:15 AM
  #610
Martin Hofer's Avatar
correct
but the won'T fit
Martin Hofer is offline
Old 06-16-2009, 04:07 AM
  #611
does any1 know what size the hex screws are, that are used throughout the bd5?
i think the previous owner of my car changed them, and the hex has stripped
and if pitch/thread is known that would be great, so i can buy some spares.
total3d is offline
Old 06-16-2009, 04:09 AM
  #612
drperry's Avatar
Should be mostly 3mm hardware... All metric, of course.
Probably needed a 2.5mm hex driver, before it got stripped...
drperry is offline
Old 06-16-2009, 07:05 AM
  #613
2mm and 1.5mm Metric
Ralf is offline
Old 06-16-2009, 08:14 AM
  #614
niznai's Avatar
Originally Posted by kschu
front arm - bd008F
rear arm - bd008R
Originally Posted by Martin Hofer
correct
but the won'T fit
Thank you guys.
Are the suspension hinge pins still 2.5 inner and 2mm outer?
does anyone know where I could find a BD5 manual in pdf?
Cheers
niznai is offline
Old 06-16-2009, 08:19 AM
  #615
snoopyrc's Avatar
correct
but the won'T fit
I think all of the Drift package Yokomo drive train parts fit the old SSG. You should be able to keep the old girl running for a while.
snoopyrc is offline
