JL EVO 3 "TUNED"
#211
ok, thanks everyone. I know I need to get a 2607, but with my racing in the balance, I'm trying to keep the spending to a minimum.
#212
Does anybody else find new Picco carb harder to restart comparing to old when the engine is hot?
I also complain about Picco glow plugs.. why they don't mark the range in glow plug body? I will send an email to factory
#213
Use GRP plugs instead.
#214
hey im considering buying one of these engines or just he JL EVO 3
and i am concered about the glow plugs, what brand of plugs can be used in these engines besides the PICCO. also are they like the Ninja engines and are really hard to tune and keep a good tune, what is the case, and can they keep up with any of the engines running at the Nats or State Tittles as i am from Australia
thanks,
mitchell
thanks,
mitchell
#216
I have used Picco and Sirio without any issues.
#218
thanks,
mitchell
thanks,
mitchell
#220
now that a few guys have had this engine for a while, can anyone tell us about the longetivity of this engine. im a little confused. it has run the SA states, it has run the WA states, it has done a club day. now after 5 lts of runnertime fuel, im still a bit worried to lean it out, each time i go to start the engine its still nipping up first thing. once started its ok for the rest of the day. i finally got somewhere close to 220F and have heard some reach the 270F mark. there is more performance to come , but while its still so tight i havent pushed the point yet. wondering if anyone else has the same issues, its not really a problem.
#221
thanks,
mitchell
thanks,
mitchell
#222
#223
it does lock solid when cold. need to unlock it wiht a screw driver on the flywheel. after 5 lts i have never had a engine still lock up like this. it performs ok, but im just still not pushing the tune so hard, im making runtime and its fast, but i see most getting around 270F on here or slightly less. it does turn over quite free when at temp. and i know its ok, but im just still taking it easy till its not so tight anymore. or maybe i should ? i guess thats what im curious about
#224
if you read previous posts on here,it was said that all you had to do was run one tank at idle then start to slowly lean-thats exactly what i did and my engines screams-ive got 2 gallons of rocket science through it, it runs at 260-290 degrees all day and holds a tune like no other engine ive ever had before-lean that thing out and really see what its got
