JL EVO 3 "TUNED"
Old 07-09-2008, 08:22 PM
  #211
mcsquish's Avatar
ok, thanks everyone. I know I need to get a 2607, but with my racing in the balance, I'm trying to keep the spending to a minimum.
mcsquish is offline
Old 07-14-2008, 02:36 PM
  #212
jeff1's Avatar
Does anybody else find new Picco carb harder to restart comparing to old when the engine is hot?
I also complain about Picco glow plugs.. why they don't mark the range in glow plug body? I will send an email to factory
jeff1 is offline
Old 07-15-2008, 01:23 AM
  #213
M7H
M7H's Avatar
Use GRP plugs instead.
M7H is offline
Old 07-15-2008, 02:27 AM
  #214
NiTrO BoOsTeR's Avatar
hey im considering buying one of these engines or just he JL EVO 3
and i am concered about the glow plugs, what brand of plugs can be used in these engines besides the PICCO. also are they like the Ninja engines and are really hard to tune and keep a good tune, what is the case, and can they keep up with any of the engines running at the Nats or State Tittles as i am from Australia
thanks,
mitchell
NiTrO BoOsTeR is offline
Old 07-15-2008, 04:20 AM
  #215
Trader Rating: 21 (100%+)
I have used OS plugs with no problem.
VA_Racer is offline
Old 07-15-2008, 06:50 PM
  #216
mcsquish's Avatar
I have used Picco and Sirio without any issues.
mcsquish is offline
Old 07-15-2008, 09:00 PM
  #217
gentleman81's Avatar
picco, os, odonell.
all good for me. but im gonna try and stay with the piccos
gentleman81 is offline
Old 07-16-2008, 02:51 AM
  #218
Mugenville's Avatar
Trader Rating: 25 (100%+)
thanks,
mitchell
Go ahead buy one you know you want to
Mugenville is offline
Old 07-16-2008, 07:35 AM
  #219
nitrodude's Avatar
Yes, the are as fast as any engine out there, dont let the price fool you. They are vey easy to tune, they keep a tune all day, and they get great gas mileage too.
nitrodude is offline
Old 07-18-2008, 06:22 AM
  #220
Pattojnr's Avatar
Trader Rating: 19 (100%+)
now that a few guys have had this engine for a while, can anyone tell us about the longetivity of this engine. im a little confused. it has run the SA states, it has run the WA states, it has done a club day. now after 5 lts of runnertime fuel, im still a bit worried to lean it out, each time i go to start the engine its still nipping up first thing. once started its ok for the rest of the day. i finally got somewhere close to 220F and have heard some reach the 270F mark. there is more performance to come , but while its still so tight i havent pushed the point yet. wondering if anyone else has the same issues, its not really a problem.
Pattojnr is offline
Old 07-18-2008, 06:53 AM
  #221
itchy b's Avatar
thanks,
mitchell
Idm plugs are good to try if you have a local supplier!
itchy b is offline
Old 07-18-2008, 09:01 AM
  #222
M7H
M7H's Avatar
I think you are making the wrong conclusion.
It is tight WHEN COLD, but not when it is on its operating temperature....
M7H is offline
Old 07-18-2008, 09:11 AM
  #223
Pattojnr's Avatar
it does lock solid when cold. need to unlock it wiht a screw driver on the flywheel. after 5 lts i have never had a engine still lock up like this. it performs ok, but im just still not pushing the tune so hard, im making runtime and its fast, but i see most getting around 270F on here or slightly less. it does turn over quite free when at temp. and i know its ok, but im just still taking it easy till its not so tight anymore. or maybe i should ? i guess thats what im curious about
Pattojnr is offline
Old 07-18-2008, 02:06 PM
  #224
if you read previous posts on here,it was said that all you had to do was run one tank at idle then start to slowly lean-thats exactly what i did and my engines screams-ive got 2 gallons of rocket science through it, it runs at 260-290 degrees all day and holds a tune like no other engine ive ever had before-lean that thing out and really see what its got
cdub is offline
Old 07-18-2008, 03:33 PM
  #225
look for smoke, watch the temp, and let her fly!
