New Corally 10SL- New World GT car
#16
It looks like you can mount the battery either down the center or side to side. On my last car we only had a center battery adjustment.So If the battery fits down the middle that's the first spot I'll locate the battery. As for the front servo thanks for the advise Pro Ten, I'll mount the servo with my angle mounts.Sure wish the car would get here before next weekend.
#17
What would you say if you could get the best from both?
I can make that happen.
#19
2s modified 235 is the only way for me.
Anyway the new Corally car looks great. The carbon side links look a little fragile though. Can they be replaced with nylon ones for a little bit of flexibility?
#20
Actually the 200mm were raced in the late 80's.back then they were called 1/11tth and Associated raced them at the worlds -I believe.We also had several run in our series (FSEARA).As for the Carbon fiber links I think I would prefer them.Especially how they connect with the O ring. Having raced another brand and being hit they pop off. Having a small wing would prevent the link from being broken and I have the parts waiting.Most oval cars had these or still have them.
#21
I totally agree with you here. However, now that everyone seems to be running 200mm cars I think the wide will soon be gone forever.
#23
They will still be around for Euro large asphalt tracks where they have a lot more power to lay down. And oval.
#26
#27
Pro Ten Holland, can you give us a little movieclip on the track of the new Corally?
#29
The 200mm cars were run as prototypes by Associated and HPI at the 1996 worlds at Ontario/California. But in the end a 235mm car did won the worlds.
