Old 07-02-2010, 05:33 AM   #16
It looks like you can mount the battery either down the center or side to side. On my last car we only had a center battery adjustment.So If the battery fits down the middle that's the first spot I'll locate the battery. As for the front servo thanks for the advise Pro Ten, I'll mount the servo with my angle mounts.Sure wish the car would get here before next weekend.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 07-02-2010, 05:38 AM   #17
Originally Posted by Pro ten Holland View Post
With the servo on an angle (no bump-steer) I get better mid-corner steering. The car is also more constant through the curves.
The laydown servo configuration seems to work well on carpet (high traction)
What would you say if you could get the best from both?
I can make that happen.
MatsNorway is offline   Reply With Quote
Old 07-02-2010, 09:18 AM   #18
Moderator
Pro ten Holland's Avatar
Originally Posted by FrostyDude View Post
Wouldn't the shock mount get in the way of running the battery lengthwise down the middle of the car? Is there a different shock mount that allows the regular batteries to run down the center of the car?
The car comes with a top deck for the main chassis for stick pack mounting.
http://www.rc-lemans.de/
Pro ten Holland is offline   Reply With Quote
Old 07-02-2010, 03:38 PM   #19
So I think that the 235mm cars will eventually disappear as everyone upgrades to newer cars, which all seem to be the narrow 200mm cars.
It does seem as if more people are running 200mm but I dont think 235mm will die out. I think they were around way before the 200mm's were, way back to the late 80s. After all, the TC's used to be converted 235mm buggies before they went to a girly 190mm. I fail to see the point of the 200mm class as they look to much like TC's. They should have just tried to re-launch the 235mm pan's instead of creating this new 200mm class that has just added another class into a reasonably poorly followed hobby.
2s modified 235 is the only way for me.
Anyway the new Corally car looks great. The carbon side links look a little fragile though. Can they be replaced with nylon ones for a little bit of flexibility?
JIM1 is offline   Reply With Quote
Old 07-02-2010, 04:28 PM   #20
Actually the 200mm were raced in the late 80's.back then they were called 1/11tth and Associated raced them at the worlds -I believe.We also had several run in our series (FSEARA).As for the Carbon fiber links I think I would prefer them.Especially how they connect with the O ring. Having raced another brand and being hit they pop off. Having a small wing would prevent the link from being broken and I have the parts waiting.Most oval cars had these or still have them.
Old 07-02-2010, 06:57 PM   #21
Thanks!
Lipo?
Brushless??
I'm still running Sanyo NiCds with a mechanical speed control.
FrostyDude is offline   Reply With Quote
Old 07-02-2010, 07:00 PM   #22
Originally Posted by JIM1 View Post
II fail to see the point of the 200mm class as they look to much like TC's. They should have just tried to re-launch the 235mm pan's instead of creating this new 200mm class that has just added another class into a reasonably poorly followed hobby.
I totally agree with you here. However, now that everyone seems to be running 200mm cars I think the wide will soon be gone forever.
Lipo?
Brushless??
Old 07-02-2010, 07:52 PM   #23
They will still be around for Euro large asphalt tracks where they have a lot more power to lay down. And oval.
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 07-03-2010, 01:20 AM   #24
Moderator
The O-rings provide the flexing in a crash. I haven't had any problems with them.
The pivot balls did need a bit of polisching for them to move freely, but after that it was one the smoothest play-free link systems I have ever seen.
Old 07-03-2010, 08:19 AM   #25
Thanks for all the helpful info Pro Ten. For those others -if I did not like the Corally I would not have ordered it.I would have not sold my other car.
Old 07-03-2010, 02:22 PM   #26
tjompa's Avatar
You mean nerfbars. They are great!
tjompa is offline   Reply With Quote
Old 07-03-2010, 02:24 PM   #27
tjompa's Avatar
Pro Ten Holland, can you give us a little movieclip on the track of the new Corally?
Old 07-03-2010, 03:05 PM   #28
Moderator
As far as I know no one has caught me running my car on tape yet. Sorry.
Old 07-03-2010, 06:27 PM   #29
That's because he's to fast. Even when running in the wet!
Old 07-04-2010, 05:33 AM   #30
V12
V12's Avatar
The 200mm cars were run as prototypes by Associated and HPI at the 1996 worlds at Ontario/California. But in the end a 235mm car did won the worlds.
V12 is offline   Reply With Quote
