Tamiya XV-01
#422
Lol!!
Good eyes! I had these already assembled from my previous TA-05' sway bars adaptation. When I remembered how painful it was to precisely cut those tiny ball joints and then assemble them together; Id said nay, better leave it like this!
#423
stormridersp - Nice chassis!
Do you have part number for the aluminum hexes and aluminum suspension mounts? I've seen they have a few different ones. Which ones do I need?
#424
The parts are:
Blue Hexes: Tamiya (#53570) Clamp Type Alu. Wheel Hub (4mm Thick)
http://www.rcmart.com/tamiya-53570-c...h=595_744_1561
Suspension mounts:
-Tamiya XV-01 Aluminum Suspension Mount XJ #54379
http://www.rcmart.com/tamiya-xv01-al...h=595_744_1561
Tamiya XV-01 Separate Suspension Mounts (1XJ) #54376
http://www.rcmart.com/tamiya-54376-x...h=595_744_1561
Tamiya XV-01 Separate Suspension Mounts (1XM) #54377
http://www.rcmart.com/tamiya-54377-x...h=595_744_1561
#425
What are the differences in the 3 different mounts?
#428
My guess is that the 1XJ / 1XJ combo in front gives 0º toe and 0º arm sweep in front. The 1XJ / 1XM in the rear gives 2.0º - 2.5º toe in? .. never measured it.
Unlike the TC version that uses that TRF/TB/TA mounts, the XV mounts give us limited suspension angle tuning.
#429
Correct.. the one piece (1XJ) is used for front and rear outer. The separates, 1XM is for the rear, and 1XJ for the front.
#430
#432
Earlier this year, new RC brand carisma displaced an 1/8 scale Porsche 959 in rothmans Dakar livery.. Fully licensed. Every once in a while I try to check for info on it and usualky nothing new comes.
Today I saw a body set for it, however it says 1/10 scale. It's a possibility since they presently have an Audi Quattro Rally body. So I do hope it's true
#433
Only problem is that the Tamiya 959's wheelbase is closer to the SWB Mini..
#435
Completely agree with you!
