HPI R40 Nitro Car Forum
#8221
Mounting a side exhaust engine....
Bojar - if it's not too late, check out these pics.
http://www.rctech.net/forum/attachme...chmentid=67755
http://www.rctech.net/forum/attachme...chmentid=67756
http://www.rctech.net/forum/attachme...chmentid=67757
I did have to tweak the header just a bit so it would clear the rear tires when using 30mm. I did have to shim the engine up about 1mm as well. I've run a four or five tanks through it and it's fine so far.
#8222
#8223
anyone have a spare set of R40 CVDs you would want to part with?? My LHS and Tower dont' seem to have them in stock and I was kind of hoping to run the car this weekend....
email me at [email protected]
dont care if they are new or used, just need the dogbone portion really....
thanks
thanks
#8224
My r40was the greatest it was set up by Hara
#8225
can anyone please tell me if there is an option part for fitting a lola body to the R40? e.g shock towers or bumper
#8226
#8227
You can also remove the front shock tower and mount the front shocks directly to the bulkhead lay-down style. I remember reading someone had done this with good results.
#8228
Originally Posted by tranced
Hey A-I!
Congrats on your beauty of an R-40.
Would you mind posting the '2004' edition steering install instructs? And where you removed the slop?
Just started a new job though so I wont be posting as much anymore. Yeah im sure you guys are sooooo sad...
But yeah look for more technical posts and findings from me from now on rather than the regular Ive got nothing better to do but chat on rctech....hehehh.
#8229
Oh also figured out how to get the battery to fit into the friggen box correctly. Im sure someone already covered this but hay you can go search through 9gillion pages if you want.
If you look inside the box. Youll see towards the front there is a bump on the inside. This is where you want to place your batterys wire ouput. So it has the room for the bump and isnt pushing on the otherside making it worse.
Which is why I couldnt fully close my battery plate without having to push it down. Now it just falls right completely down and sits all by itself. It was a wonderful thing to watch.
Another cool trick was I used electrical tape and bundled up the wire to the wire adaptor that I guess for me I stick inside of the box. I then take the other side and neatly round that onto the back of that bundle and tada. Clean wires that I can now easily shove into that overly overly small wire compartment. Then run the wire around the top side...not bottom as that will make the battery stick out some. And tada, clean battery install.
BTW funny stuff. The cf battery plate , 6.0grams , stock 6.3....wooohooo im livning la vida loca. I was expecting it to be heavier actually so I guess thats good its lighter...lol.
#8230
Anyone know what hop ups come in the hara/2004 edition r40 kit?
#8231
Originally Posted by fastharry
a common problem on a few cars......put new knuckles on...and don't hit anything...But I will tell you my freind has tried the GPM knucles and loves them....
your explanation is acceptable BUT even if I hit anything using my V1R, i have yet to experience this problem. I guess the discussion on the issue of HPI Plastic parts not being that sturdy is true.
#8232
R 40 2 speed one way
Hi!
Last night while we asembling a R40, we could not assemble the 2 speed. I thnk there must be a one way bearing in the region that i plotted, but we could not find it. How can we solve it?
#8233
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally Posted by ontheroad
Hi!
go back to page 14.....did you install the part# 87082 into the spur gear?....if you did,it should have a one way bearing in it..if it doesn't,call hpi's custmer service...
#8234
There's always parts missing in a kit when your doing a late night build
always appears the next day though, strange that.
just a quick question about the lightweight JP clutch bell, is it a straight swap with the stock r40 clutch bell?
#8235
Yeah we assembled that part what there is no one way in it and it has to be preasembled. But there is a point that in this page of manuel(In parts list at the left column) it shows #87082 like it has no one way in it.
