Losi 8ight building and setup
#4051
Hey
Does anyone knows the difference between the chassis of 8ight RTR and 8ight Pro Kit? If I want to upgrade the engine to a OS, will the RTR chassis work?
Thanks!
Thanks!
#4052
if you wanna use a starter box with that OS all you have to do is change the motor mounts to either the kit version ones or the king headz ones and the RTR chassis will work
#4053
kmaheartless- The best thing to do is go through this thread because there is so much valuable info in here.
#4054
Losi parts are slowly starting the come into Horizon. The aluminum top plates will be hitting the shelves soon
#4055
#4057
ok i know some of you 8ight users are using digital servos so who's using AA reciever packs and in what configuration?
#4058
Who's using the TKO ceramic bearings and is there any special maintainance needed? Believe it or not, I take off my motor, tires and radio tray before throwing my buggy in the dishwasher to clean it. No problems so far. I do re-oil the bearings periodically of course.
#4059
WOW! That sounds crazy to me but if it's working for you.. Actually, the bearings are really the only thing I can think of that would get damaged from that (maybe a little rust in the CVD joints), it shouldn't hurt the plastic a bit. Creamics should be better as they are more rust/corrosion resistant than conventional bearings.
#4061
#4063
ya so my worn clutch shoes lead to other problems. what are people running for a flywheel, shoes, clutch nut, etc. the whole works. mine is toast and i need a new one but not sure what really works with the flex in the chassis and the fuel tank bing so close.
thanx
thanx
#4064
#4065
