coloring your gas?
coloring your gas?
i just got a gallon of this gas: http://carolinasrc.com/Webstore/Scri...idproduct=4092
and it looks like water... and its also VERY hard to tell how much gas i have just by looking at my gas tank... cuz its clear.
i remember reading somewhere that you can add a few drops of food coloring, i was wondering if this is safe, and how many drops should i use per litre?
also, when should you take the temp of your engine, after 1 full tank of driving? 2 tanks?
i was thinking red... but black sounds like a good idea too.
thanks
edit: k, i just drove my car around, it was in the cold and wind. i drove 2 tanks through it, not quite as hard as a racer would, but i drove it like normal.
my questions are:
1. it was running good, then it started bogging out, so i opened the HSN about 1/4 turn, then it ran fine, then it was bogging out again... so i checked on it and noticed it wasnt where i had set it before, i think it rattled itself closes a little bit? is that possible? so i richened it anohter 1/4 turn and it ran fine. but i was letting a friend or 2 try it, and sometimes it completely died out on them, i dont know if it was the engine fault or if they were accelerating way too fast (their fault)
2. i took the temp after tank 2 and the temp was only 110 farenheight... i let it sit for about 45 seconds by accident in the cold/wind before i checked, so i can imagine it cooled off, but how do i increase my engine temps? (not my header temps, i burnt my damn finger on it!! again!!!!) i heard engine temps should be near 220 F?? is it just because im running in the cold wind/ mud/ ice?
thanks.
Cold weather tuning
Other people are welcome to correct me if im wrong, but I believe that you are supposed to tune to performance, not temp in the cold weather.
I have an OS V-Spec which runs at 220* F in the summer when I race, but when I raced it a month ago in 10* weather, it temped at 170* with minor tuning adjustments.
So i guess in conclusion, dont try to get a specific temp in cold weather, tune to performance.
thanks
all right, awesome thanks, thats exactly what i was looking for.
thanks
my questions are:
thanks.
thanks
my questions are:
thanks.
MM
www.massivemods.com
Your head temps in cold weather will be considerably less because of ambient temp. Sounds to me like you have a lot of shims under your head button.. Try removing .1 to .2 so that you have a total of .4 to .5 head shimming. This will give you a cooler header and hotter head. But as mentioned tune for performance not temps. If you cant keep it hot enough wrap alfoil round the head ...
MM
www.massivemods.com
MM
www.massivemods.com
i have no idea what shims are, what they do, how to remove them, how to tell how many i have..
what would be the problem if sometimes when i start it, i let it idle for about 20 seconds, then i accelerate... sometimes quite fast, and it dies. is it just because i need to idle it for a bit longer, or is it not getting enough gas? other than that it runs perfectly, i love my lrp .28... almost too much power, damn hard to control on ice, grass, cement, gravel.. etc.
correct me if im wrong but your idle could be set to low, you should have a idle knob on your radio and twist that a little higher and then see if it dies when accelerating, if it does come back
i think it was just the way my friend was driving it... it only seemed to happen to one friend (the idiot of the group).... i drove it today and it was running fine. i think what happened is i was curious one day so i took my HSN needle all the way out to see how it worked, and when i put it back it it wasnt quite as tight as before.. and i think it kinda rattled it self closed about 1/4 turn, i opened it a little and it seemed to solve the problem.
ps: hondarules
If your HSN is rattling back and forth, that's a very bad thing, lol! That can be detrimental to a motor, supposed it rattles inward more and more, that's leaning it out as your run it... And we all know that can be a bad thing!
If its that easy to turn or it moves on its own, I suggest taking it back out and replacing the o-rings on the needle...
