JP engines
#106
Where can I buy a Zac pipe from. I was trying to get one of there modded motor's but I can't find them anywhere.
#107
A lot of my friends are selling their OS ZAC very cheap (new and used) since JPs have more power bandwidth especially in the bottom. Too bad you are in Australia
#108
Idle Gap
Hi Guys,
I've run my JP FX in and tuned it to the best of my ability (needs some practice, I think!). What surprised me however, was that the gap on the throttle barrel wasn't very big - I see figures of 0.5mm to 1mm often quoted.
My engine is running @ 108 Degrees C after a good 10 laps of hard running. When release the throttle trigger after a flat out section, the revs go to idle relatively quickly (i.e. don't stay high for a few seconds - which I think indicates LSN too rich) and the revs don't increase.
I've used the pinch method (i.e. pinching the fuel inlet tube) to see if the engine is running rich or lean. When I pinch the tube next to the carb inlet, the revs rise for 0.5 to 1 second and then die off pretty quickly. This should indicate an ok tuned LSN, no?
Have a look at the pic attached, you can see my idle gap - let me know if this is ok. BTW: Normally the insert is in, I just took it out to let you see the gap better.
Cheers, Mark.
Cheers, Mark.
#109
Looks ok to me and the explanation shows that its in tune.
I would have thought you could run the engine hotter than 108. What are others running theres at
Cheers
Cheers
#110
Cheers
Cheers
I was just at the end of my run-in cycle, so I'm just building the temp up slowly. I've got the JP FX with ceramic bearing, does this mean it can run a little hotter than normal?
No one else is running JP FXs at my track, so I'm not sure what temp I should be running the engine at. Any tips would be welcomed
Thanks, Mark.
#111
Originally posted by markp27
Cool
Thanks, Mark.
Cool
Thanks, Mark.
No, the bearings doesn't mean you can run the motor a little
hotter. On the other hand, ideally, the motor should run a bit
on the cooler side since the ceramics allow the internals to
have more ease and smoothness when in motion.
About the temps..
If you are able to run it at your current 108 C with ample power
and run time, I suggest to keep the temps within that range.
But ofcourse, this number will always differ depending on the
current conditions on the day you are running the motor at.
#112
Cool
Thanks, Mark.
Cool
Thanks, Mark.
#113
Originally posted by jwf-ronni
Hello markp27,
About the temps..
Hello markp27,
About the temps..
#114
Originally posted by MrChan
I have been running at my track about 97 C ... give me enough power ..
I'm running the 3-port version. The other day a guy setup a radar-gun to check the speeds of the cars at the fastest part of the circuit.
A guy running an MRX-3 1/8th got 92 kph, a 1/10th runner with an MTX-3 only managed 60 kph and me, a solid 90 kph
#115
and run time
and run time
#116
Re: Idle Gap
#117
Re: Re: Idle Gap
Originally posted by daniz24
Maybe you could lean your LSN a little bit more. And yes, your idle gap is about the same to us.
Cool. Is that means they now allowed you to join the 1/8th scale racing with your 1/10th car?
#118
Geez, are you sure it's the 1/8th scale and not the 1/5th scale lawnmowers?
#119
Originally posted by InitialD
It's the car I tell ya...
#120
D!!!! don't blab about the car stick to the plan remember!!! The car is a piece of junk, made out of glass in fact! It's better to buy something else
The lawnmowers were impressively fast: 72kph
