Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 10-10-2012, 04:24 AM
  #1321
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Starting my build tonight!!!
Posvar is offline
Old 10-10-2012, 05:59 AM
  #1322
Trader Rating: 1212 (100%+)
Originally Posted by Eric Summers
Package tags say "Always the Best"
Too bad the manual isn't.
I called Kyosho on that and they agreed LOL. The "proper" way to install the shock bushing is to use the 4.8mm and crush them, but I see that as a little errrr queer at best. I'm gonna use the 5.8s I have and cut them to the same size.
bigwavedave33 is offline
Old 10-10-2012, 06:09 AM
  #1323
silvalis's Avatar
Trader Rating: 29 (100%+)
First race meet with the RB6, team japan setup with pink/red, changed to pink/gold and ifmar pins and the buggy was a dream to drive.
I notice that it tends to nosedive a bit. Nothing wrong with that, but didn't expect it on the first jump, dug the nose into the dirt and had to fight my way back from last to 2nd. I also notice that with my current setup (team japan, pink/gold, 35/30 oil, silver losi wide ribs/red pins) steering is good under power but if i let off a bit and the weight transfers back to the front, the fronts grab a bit and the rear gets a bit loose.
I'm going to fiddle with the shocks a bit, currently on 35/30wt f/r, might change to 40/35 or 40/40 as the rear is still a bit bouncy on my bumpy track. Any comments on slowing down the rear?
silvalis is offline
Old 10-10-2012, 06:23 AM
  #1324
can't believe I beat you building it... I'm running saddles to start out with. I'll post some pics tonight when I get done with the wire clean up.
Old 10-10-2012, 08:04 AM
  #1325
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by cantrell8
your going to need all the practice you can get, competitions is going to be high this weekend!
oh i know it! But, it has come down the wire here, building, wiring and painting the car. I don't think im going to see clay until friday at TRCR. It's ok though, team Matesa is supposed to be saving me a spot at the Kyosho table
Cpt.America is offline
Old 10-10-2012, 08:05 AM
  #1326
just got mine should i boil some of the plastic parts to make it stronger?
hollywood7 is offline
  #1327
Nope, the car will be money right out of the bx
Old 10-10-2012, 08:32 AM
  #1328
Bitchen!... make sure to take a photo of your final build with your electronics layout.
Old 10-10-2012, 08:58 AM
  #1329
Derry's Avatar
Trader Rating: 27 (100%+)
Here is my layout..
Derry is offline
Old 10-10-2012, 09:30 AM
  #1330
t8rtot's Avatar
Trader Rating: 14 (94%+)
are your wires going over your wing mount? weird camera angle?
t8rtot is offline
Old 10-10-2012, 09:36 AM
  #1331
Derry's Avatar
in between. Yeah, that angle does make it look over.
Derry is offline
Old 10-10-2012, 09:52 AM
  #1332
gas1313's Avatar
Trader Rating: 18 (100%+)
Default Rims
Does the rb5 rims fit the car front and rear! Sorry if this has been ask but did not see it! Thanks
gas1313 is offline
Old 10-10-2012, 09:53 AM
  #1333
Moderator
Posvar's Avatar
Will do Brandon! Gonna be neat and tidy!
Posvar is offline
Old 10-10-2012, 09:56 AM
  #1334
Moderator
Posvar's Avatar
Yes on the rims!!!
Posvar is offline
Old 10-10-2012, 10:04 AM
  #1335
DeanV's Avatar
Finished mine over the weekend. The plastic battery posts with clips just irked me, so yesterday morning I modified the battery holder to accept my aluminum posts. Since I am running the standard lipo, I have a spare battery holder just in case I need to go back
Starting with the Japan setup with two minor changes. 0 degrees in the caster block (instead of 4) and .5 degree rear hubs (instead of 0).
Dean
Attached Thumbnails Kyosho Ultima RB6 & RB6.6 Car Thread-2012-10-06_15-34-18_972_1024x768.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-2012-10-06_15-59-14_880_1024x768.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-2012-10-06_15-59-30_215_1024x768.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-2012-10-09_10-22-03_612_1024x768.jpg
DeanV is offline
